Loader Rams turned 180?
/ Rams turned 180? #1
rdinatal
Gold Member
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
While I was done some dirt work Saturday I was noticing... There is a lot of dirt, dust, crud spilling over the bucket and getting on the hydraulic rods. Why the rods down towards the bucket? Has anyone turned them around and swapped the hoses?
This will keep the rods and seals away from crap. Less contamination and seal issues.
-R
/ Rams turned 180? #2
I think if you turn them around the cylinder end with the hoses will move to much .....
/ Rams turned 180? #3
I think the chances of damaging the base end hose & fitting would have a greater chance of happening than "nicking" the exposed end of the cylinder if it were reversed. :2cents:
/ Rams turned 180? #6
Dirt bikes have shields to protect the stanchions and seals from rocks and dirt. Weld up some shields and mount them over the stanchions. All it would take is a length of sheet steel bent lengthwise at about a 45 deg angle and some brackets to mount them. Or...don't pick up an overflowing bucket load. :thumbsup:
/ Rams turned 180? #7
Spill shields ? are a good way to keep the cyl. & pins somewhat clean & protected. Not a big deal to fab up.
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
