Rake Rake stand/jack
/ Rake stand/jack #1
Charlie175
Virginia
Mahindra 2015 gear
What has been the best option to add a stand of some sorts to hold the rake front up when it is off the tractor? Sure would make hooking it up easier.
/ Rake stand/jack #2
Was in the same boat, one day years ago and had enough so I took a few minutes and made this. It is not pretty and don't laugh, it works really well and I used material I had laying around even the homemade T-handle bolt. Just loosen the T-handle bolt and the pipe-stand slides right to the ground, tighten the T-handle bolt disconnect the 3PH and off you go. After hookup, loosen the T-bolt and pull up on the pipe-stand, tighten T-bolt and off you go. Fast and simple.
/ Rake stand/jack #3
I'm not a welder so I just use a jackstand. I use the other one on a rear blade. JC
/ Rake stand/jack #4
I use a cinder block.
/ Rake stand/jack #5
Nothing for nothing but my stand goes wherever and anywhere the rake goes, totally and instantly adjustable for ground contours.
BTW, My wife just pointed out the bent pipe, yes I went to drive off once with the rake attached and the stand in the down position. I made the stand, I'm getting older and I can do those things.:D
/ Rake stand/jack #6
That's a great stand gizmo...hope you don't mind but I think I am gonna make a bolt on version of your design. I can weld a little but I don't have a welder.
I am starting to think that having a mig or tig is a "have to have kind" of thing for the farm.
/ Rake stand/jack #7
Charlie175:
If you have reversible gauge wheels you could mount the wheels in front of the rake. Jay
/ Rake stand/jack
Good ideas, I was going to look for a jack stand to see if I could adapt it. I also thought about one of those old ratchet car jacks.
I don't have gauge wheels.
/ Rake stand/jack #9
View attachment 105111 View attachment 105112
View attachment 105113 View attachment 105114
Those "feet" are the reason I learned to weld....along with bucket hooks. I still havent gotten around to making the impliment feet yet though
/ Rake stand/jack #10
I picked up a trailer jack that pivots to bolt on my rake. HF special of course. Works great on my Land Pride rake plus swings up well out of the way.
Vernon
/ Rake stand/jack #11
You're right that propping up the rake front end makes it easier to hook up. I tried various things and then just settled for a block of 6x6 cut to size.
Then I found that for my York rake, if I put the scarfer down and parked on level ground, it would be level.
/ Rake stand/jack #12
This is a stand I made for my york rake several years ago. Very simple, two short pieces of pipe and some misc parts. It works very well.
/ Rake stand/jack #13
Real nice Bob. Despite the fact yours makes mine look like #$*@, Nice job ;)
/ Rake stand/jack #14
Thanks Gizmo ! I did some maintenance on my old rake this year and give it a fresh coat of paint too. :) The stand is the same basic idea as yours. They sure work good in keeping the rake in position for another 3pth hookup.
/ Rake stand/jack #15
Hmmmmmm, yeah thats it, the fresh paint. Never mentioned fresh paint.:cool:
/ Rake stand/jack #16
Charlie,
I'm not sure if this is the best option or not, but here is how I built a stand for the rake I am currently building from scratch.:
Here is the link to the entire 18 pages so far CLICK HERE
Larry
/ Rake stand/jack #17
GuglioLS said:
Charlie,
Larry
Larry,
That is sure a purdy rake. What a great job ! Good idea in the stand too.
Bob
/ Rake stand/jack #18
Thanks Bob,
I took a closer look at your rake, Do I see a drop down blade attached in there somewhere? how does that work out? seems like that would be real handy. DId you add that and the gauge wheels? Your addon stand is very solid, nice rake.
Larry
/ Rake stand/jack
Good idea guys, thanks for sharing.
I haven't decided what to do yet.
/ Rake stand/jack #20
GuglioLS said:
Thanks Bob,
Larry
The drop down blade is an option on all york rakes and came with my rake ( 25 yrs ago ) when i bought it. The blade is Very handy. Its not " beefy " enough to dig ditches but for something like crowning up a roadway it works real well. A blade also adds alot of weight to a rake and makes it more stable ( in My opinion ) The gauge wheels came with my rake too.
Bob
Baby Goat Decorative Statue (A61569)
Baby Goat...
2018 Nissan Sentra Sedan (A61569)
2018 Nissan Sentra...
207271 (A52708)
207271 (A52708)
2016 CATERPILLAR 259D SKID STEER (A62129)
2016 CATERPILLAR...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
2018 Ford F-350 Crew Cab Landscape Dump Truck (A61568)
2018 Ford F-350...
