Raising the 3 point the loader also rises
/ Raising the 3 point the loader also rises #1
Bobog
Branson 2400
Good day all. I
have been a long time reader but this is my first post and hoping that someone here can help as I am not finding the answer anywhere.
I have an older Branson 2400 with a BL00 Loader we got used 2 years ago. The issue we are having is when raising the 3 Point the loader also rises. We have been having this problem since we got the tractor. I've been working around it by lowering the bucket when it gets too high or letting it rise to the top when running the box blade on the driveway.
We have verified all the hydraulic lines are ran correctly. The only thing I see that might be out of place is one of the pistons at the top of the valve for the loader is not level with the other pistons, don't know that it matters. If I hold the joystick forward making it level everything seems to work as expected, but I do not see a way of adjusting it. (Photo Attached). I don't even know if there is one, or if this is the issue or not.
I' m hoping someone has an idea on what is causing the issue and how I might go about fixing it. I am at my wits end.
/ Raising the 3 point the loader also rises #2
It sounds like the upper spool is for the loader raise/dump circuit. It's not seating in the fully closed position. When the 3pt is raised, especially if there is an implement on it, there is back pressure in the system. That sneaks past the slightly open loader spool and raises the loader.
It might just be a detent in the valve that is not working correctly. Maybe it's stuck or the spool itself is worn where the detent seats. Having to work against the weight of the joystick can't help.
Thanks for the quick response idea. I agree, it is like it is slipped past into the loader and yes it is worse with an impament on. You describe the issue much better than I did. Thanks
Taking the joystick off didn't seem to help get it to go down so i dont think it is a pulling issue with the weight of the joystick. Using a pare of pliers to move the valve up and down feels tight in both directions and returns to the center point with a touch of a snap. Feels just like the curle ones does.
How would I go about checking for the detent. Do I need to figure out how to remove the plunger on the valve to inspect it or is there an adjustment that wouls allow me to to adjust for center?
/ Raising the 3 point the loader also rises #4
Did the float feature detent properly on the raise lower spool?
Occasionally the can on the opposite end of the from the joystick can fill with crud restricting spool movement. One of the first signs can be the float detent no longer works or is very difficult to engage.
The centering spring mechanism is also inside this can. Use caution if you decide to remove this can since there could be spring and detent balls wanting to fall out.
That was a great thought. The float works without fail and as it should. The centering (spring return) seems to go back to center without fail as well.
/ Raising the 3 point the loader also rises #6
Bobog
In the picture on the first post which spool is the raise lower spool. Which way does this spool move to raise?
Updating the image with orientation of the loader valve, adding some notes to the first image, and providing a loader Assembly diagram for a loader that is close to what I have.
If you pull the joystick back towards you the (The Seat) the loader will rise. If you push it forward the bucket goes down.
If I hold forward with just a little bit of pressure to keep the spool level with the anchor point the 3 point does not cause the loader to rise. As a side note, bucket curl spool which is closer to the steering wheel (unseen in the picture) is level with the Anchor Point.
In the Assembly diagram, I believe the one I am having issue with is #2. I am new to going this deep into a valve so please be kind ;). I am unsure how to remove the spool, and as you said, don't want to have parts fly all over the place. That said I am happy and look forward to learning new things.
Appreciate the patience and support
/ Raising the 3 point the loader also rises #8
Bobog
Should be no need to remove the spool completely. I would start by carefully removing the centering spring cover on the lift spool and inspect those components to see if something has worked loose or looks out of place. What I do not know is if any parts will fall out when you do this.
3rd grader here, Spring cover, would that be #4 on the diagram?
/ Raising the 3 point the loader also rises #10
Yes item 4 in the diagram. Looks like two bolts hold that cover. I would suggest slowly loosen both screws an feel for spring resistance on that cover. Looks like centering spring assembly should be captive on the spool but suspect will be some spring load on that cover that should decrease to little or no load as you remove the screws.
I do not see detent assembly on parts break down
/ Raising the 3 point the loader also rises #11
This manual for Prince loader valves shows how the detent springs work: http://www.princehyd.com/Portals/0/valves/LVManual.pdf
Page 11 is a center detent. Yours is likely similar.
The balls get forced out into a groove in the detent sleeve. If you can feel the center detent when pushing the lever forwards to drop the loader, then I think that your detent sleeve or its equivalent is worn out in the out (lever down) direction and is letting the spool come out. If you can't feel the detent in either direction then maybe the spring and/or balls are gunked up and not moving.
If it's worn, you probably can't get parts. The easiest thing would be to replace the valve.
Whatever you do, when it's working you should find a new boot and clean and lube the linkage before putting it on. Those parts are often made of pot metal and don't like being exposed to the elements.
I really appreciate everyone's help. I will check the spring and the detent that has been called out in the next few days. I was just called out of state and will not be back until later in the week. So sad since I felt like I was making progress. When I get back I will check these things and let everyone know.
Thank you all. I pulled the spring cover as suggested, the spring assembly can out in my hand. Somewhere along the life of the tractor it appears someone made an adjustment to lighten the spring loading and only had one or two threads left holding the spool on the spring, and all the spring loading was held in by the spring cover. I tightened the shaft that ran up to the spool to its stop and everything went into alignment.
The 3 point now works as it should without causing the loader to rise. For that matter, all the hydraulics work better and there is much more power and control of the FEL.
Thank you everyone for your help.
/ Raising the 3 point the loader also rises #14
Greetings Bobog,
I have been following this thread and I know I'm not the only person who appreciates your posting the solution to your problem.
Thank You,
Eric
2018 Peterbilt 348 T/A Rollback Truck (A59230)
2018 Peterbilt 348...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
LMC 6' SOIL CONDITIONER (A59823)
LMC 6' SOIL...
