Raising an extension ladder
   / Raising an extension ladder #51
hows this
   / Raising an extension ladder #52
Here is my picture. And the view,
   / Raising an extension ladder #53
Some of these photos bring Wyle E. Coyote to mind. :)
   / Raising an extension ladder #54
Ha. Brings back memories. I always sort of felt sorry for the coyote. The roadrunner had little personality.
Given my current age and situation, I’m at the point where I won’t go up on anything where if I fall I will get seriously injured.
Whoever invented those light bulb poles to change the lights is a genius!
MoKelly
   / Raising an extension ladder #55
We had a roof ladder at work, long time back when in my 20's and quite a bit lighter.
From parking lot to roof, over two stories, ladder was maybe 40-50 foot fiberglass.
We used to part climb, part crawl as the ladder flexed many feet.
Probably installed stairs. Had lots of equipment up there, used to only send us younger/lighter people up to fix/replace.
I think the ladder was maybe at 30 degree angle, so you weren't exactly climbing to get up it :)
   / Raising an extension ladder #56
How about a telescoping pole with an end that will grasp light bulb. Available on internet and home centers
I've done something like this where it's inconvenient to use a ladder (we've got a spot under a high deck where there's lights on the underside and nowhere to lean an extension ladder on, and I don't have a tall A-frame ladder) - I have a long wooden dowel, and I made a cushion on the end of it with some inside-out duct tape - basically loop the tape sticky side out, stuck that on the end, and then more going from the side of the dowel up over it and to the other side, and finally some duct tape in the proper direction to hold the mess on the dowel. This then was raised up to the light bulb (an R40 in this case), and it had plenty of grip to unscrew the light and hold it so I could retrieve it; then I stuck a new one on the duct tape and reversed the process to replace the bulb.
I've been known to get on roofs if I have to, but I'll do anything I can to avoid a really tall ladder unless I can't find another way. Once to patch a steep roof, I anchored a climbing rope to the bottom of a tree on the other side of the house, threw the rope over, and used prusik knots to make sure if I slid I wouldn't fall.
Above all, if you choose to do something funky with a tall ladder, make sure you've got a friend there watching over you - and do it on a day your wife isn't there!
   / Raising an extension ladder #58
Just a few years ago I had no hesitation getting on any roof I have and some are pretty steep. Now, I'm more hesitant. Age I guess does that.
Old guys break easier.
Bruce
   / Raising an extension ladder #60
I need to extend as far as possible a 28' extension ladder onto a 10/12 pitch roof to change a HPS bulb every 3 years. So much for their 8 year warranty,
I run a heavy rope over the top of the roof and hook the ladder to a garden tractor on the other side to pull the ladder up all the way. The bottom of the ladder is inside a extended tractor bucket near the roofs edge to hold it steady. With the rope holding the ladder just in case the tractor moves I feel fairly comfortable to reach the peak while climbing on the laying down ladder.
I don't like it but you do what you can to get the job done. I thought about just putting in a light I can reach with an 8' step ladder and forgetting the high one.
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
JOHN DEERE 700 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 700...
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
