Raised Garden Beds
/ Raised Garden Beds #21
We found some parts totes that had been removed from a factory. They had drain holes already in them. They were roughly 3’x3’ by 18 inches deep.
/ Raised Garden Beds #22
Beds look great. For drainage, you can use HugelKulture where you put small logs and branches in bottom one foot of two foot deep bed. Then cover with garden soil/mix. Look it up as it has been really taking off in gardening whereas you keep carbon in the ground, reduce watering and will compost over time (in addition to compost used in your garden soil). I used galvanized and red cedar in our beds and the tractor not only brought wood fill and soil fill directly dumped into bed, it also allowed me to carry the beds that were built in the shop during winter to the outdoor site in the spring. The tractor also did the post hole digging to put up the deer fencing. ECCDBEE8-4C11-4F74-9F20-B1E08366958A.jpeg
/ Raised Garden Beds #23
Yours are a lot fancier then mine. I just put two treated 2x8's on thier sides and cut an 8 footer in half to make each bed 4x16. I have 24 beds so far and room for another 40 or so of them. I bought 4 dump truck loads to fill them up and used the bucket on my backhoe to pick up the dirt and spread it out in the beds. It's time consuming, but overall, pretty effective.
Before building the beds, we tried amending the soil a few times a year, and disking it with the tractor. We could get a a lot to start growing in the spring, but when summer hit, we couldn't put enough water on it to prevent the soil from becoming concrete. It was a losing battle with poor results. Having quality dirt in the raised bed has been a night and day improvement!!!!
/ Raised Garden Beds #24
Are y'all setting these beds directly on the ground, or elevating them on feet? If elevating, how are you protecting against them becoming havens for things like snakes?
/ Raised Garden Beds #25
for me, keeping it simple is a big part of doing this. The boards are sitting on the ground, anchored in place with rebar and clamps.
snakes seem to like to lay right at the bottom edge of the boards. We killed a copperhead in there a couple months ago, and last year, killed three snakes. I'm sure they are hunting mice, which probably enjoy eating the veggies. This year we are laying red cedar mulch in the walkways. It's expensive, and time consuming, but where it's been done, there are no weed, you can walk there right after watering, and we're hoping that snakes will be more obvious.
/ Raised Garden Beds #26
Eddie, the buckets next to the trees, is that a drip system you have? Does it have a tube all around the tree or just a hole in the bucket?
/ Raised Garden Beds #27
Won't the snakes hide in the mulch? Seems like that would be a nice cool place to lie in wait for prey.
/ Raised Garden Beds #28
Can't speak for him, but I've done that with just a hole in the bucket. 1/4" or so, seeps slowly enough to soak in around the roots.
/ Raised Garden Beds #29
Quarter inch hole in the buckets that we fill up with a hose, and it slowly drains out. We believe that we get more water to the trees that way.
Mine are directly on the ground. We don’t have snakes worth any concern in N. Illinois, except in the woods and by the rivers. I know thousands die a year from grass snake bites, but in 25 years at this location, I’ve only seen rubber snakes I put in my trees to fend off grackles.
/ Raised Garden Beds #31
Getting ready to do the same for strawberrys.. Would u PLEASE share the dimensions..
They look fantastic.!!!
So many responders, so I’m not sure who’s dimensions you are looking for.
For mine, the side beds, or legs of the “U” are approximately 3 feet wide x 18 feet long. One leg is approximately 22” deep and the other is 15” deep. The base of the “U” is 6 feet wide x 12 feet long x 22” deep.
Peppers and such are in the deeper/taller leg, tomatoes in the shorter leg. Squash, zucchini, and cucumbers in the base section. I’ll grab some current pictures. Everything has taken off like crazy. Eating squash and zucchini several times a week from only two plants of each.
/ Raised Garden Beds #33
Kicking around an idea for an open area on a mild slope that's proven to be too rocky for planting.
Thinking of setting a frame like you would for a deck, 4x4s sunk into the ground, connected by 2x6s leveled about 18-24" above ground. The planters would be made separately and placed on top of the frame. Planter boxes would be sized to be able to be lifted off frames, even when filled with dirt. That would be determined by the capabilities of the tractor involved. In my case, probably no more than 2' x 4' or maybe 3' by 6'. Unsure of depth, maybe 12-18".
They'd have to be spaced 8-10' apart to allow for mowing and other tractor movement between them and spraying of weedkiller under them.
2019 Toyota Camry Hybrid Sedan (A64557)
2019 Toyota Camry...
Husqvarna MZ61 Zero Turn Mower (A66285)
Husqvarna MZ61...
John Deere 1530 Tractor (A66285)
John Deere 1530...
1996 Champion 540P (A64126)
1996 Champion 540P...
28 Gauge R Panels (A65640)
28 Gauge R Panels...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
