Rairoad Ties For Retaining Wall?
   / Rairoad Ties For Retaining Wall? #31
....I've seen wire cages filled with 3" stone that might suit your purpose as a retaining wall....Jack
They are called gabion baskets, we usually use those for severe erosion control areas. IMO, not the most attractive things.
   / Rairoad Ties For Retaining Wall? #32
   / Rairoad Ties For Retaining Wall? #33
See if you can buy a couple of used highway barriers.
If not in a hurry, I can get them from the local concrete/precast plant for $100 each. A 12’ Section weighs ~ 5,000 lbs., a 20’ comes in around 8,000
   / Rairoad Ties For Retaining Wall? #34
Is that price for a new or a used one?
I've occasionally seen used ones at a local gravel plant but never asked about price.
   / Rairoad Ties For Retaining Wall? #35
The other thing that is common around here are what are sometimes called "mafia blocks" most cement places have them, they are 2' high, 2' wide and 2', 4' or 6' long. They are heavy though.
Aaron Z
   / Rairoad Ties For Retaining Wall? #36
Whatever is sitting on the lot. Sometimes the new ones look used. They are normally leftover/return to plant from the readi-mix operation. They get poured into barrier and block (2x2x?) molds.
   / Rairoad Ties For Retaining Wall? #37
Actually, there are some very attractive gabion basket installations. It's ALL about what filling stones are used and how the basket is filled. Gabion installation is very forgiving, will last for a very long time and will allow water to easily pass thru.
In the end, there is no quick, easy or cheap retaining wall. Like others, I've used railroad ties - I'll never use them again.
   / Rairoad Ties For Retaining Wall? #39
Did you do the math on just pouring concrete? Maybe used ties as forms?
   / Rairoad Ties For Retaining Wall? #40
Have not read through the thread so this may be a repeat. On the west coast many of the railroad ties are treated with creosote. Depending on age and wear of ties it can smell strong, especially in hot weather, and is not healthy. If you expect to be spending time in the shed ties may not be the best idea or may need to put plastic over front side as well.
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2012 Club Car Precedent Electric Golf Cart (A55758)
2012 Club Car...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2019 DODGE RAM 5500 HD SERVICE TRUCK (A54756)
2019 DODGE RAM...
2015 Chevrolet Silverado 3500 4x4 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
2015 Audi A4 Sedan (A55758)
2015 Audi A4 Sedan...
