Rainwater System / cleaning equipment and garden watering
   / Rainwater System / cleaning equipment and garden watering
I’ve considered doing something similar. I have a 400 ft well super hard water and slow recovery that I’m nervous to use for any type of irrigation or heavy usage. There are 2 other hand dug wells from late 1700s that pretty much dry up every summer. So something like yours with a pressure tank might be the best solution.
I don’t think you will be sorry. Having an extra 1000 gallons of clean water is helpful if you have gardens. The initial investment is high, but having fresh rainwater makes you quickly forget.
My old well has hard water too. I feel your pain. I don’t use the well anymore except for extremely low flow conditions our spring. My neighbor had a problem like yours and he had a well guy come in with a new rig/system that spun chains down inside the well deep clear to the bottom and that really got it flowing again.
I use a HF 110 volt mini water pump with my IBC totes. That provides ample pressure to feed my triplex pump on my pressure washer. The pump is mounted on the pressure washer cart and is plugged into an outlet in the shop with a GFCI connector. Problem with rainwater collection is straining out the junk that collects in the gutters so I use a screen at the gutter terminis and drail the flush the totes regularly. A good rain event will completely fill both of my 350 gallon totes in one shot. I also add a coup,e ounces of H2O2 to each tote to eliminate any 'green' matter in the tanks and the tanks are covered with black film glued on to prevent sunlight from growing algae. At least 4 years now and zero issues. I do drain them in the winter so they don't turn into huge ice cubes.
Great info. Couple ounces per tote makes sense. Thanks for the tip!
   / Rainwater System / cleaning equipment and garden watering #13
No problem. I covered the outside of the totes with black plastic weed barrier film and I used spray contact cement to adhere it to the totes. I still get a bit of green water in the totes but the H2O2 eliminates that. The shop and attached garage is 40 x 80 and the roof provides more than enough rainwater to keep them filled constantly. I could probably add another 4 totes for rainwater, but 2-350 gallon totes is plenty enough enough for my needs. My HW pressure washer don't care if the water has a green tint to it. One thing I did do is I added an inline stainless strainer to the PW input line, beterrn the HF water pump and the PW inlet. That catches any crud that might be in the totes that got past the downspout strainers. You can buy the inline downspout strainers at any home improvement store. Got mine at Lowes. The seperator screens are angled so the leaves and debris slide off the screens as the water flows through them. Have had that setup for at least 10 years now. Just be sure to get IBC totes that held food grade product that will wash out easily.
   / Rainwater System / cleaning equipment and garden watering #14
What kind of water pressure does it produce? I could see this being an option for my drip irrigation. Gonna look them up. Thanks for the idea.
I’ve been using a Rain Brothers pump setup pretty similar to this for a couple seasons now also pulling from a tank, mostly for garden irrigation and some light equipment wash-down. I’ve got mine tied into a drip irrigation system that feeds a mix of row crops and raised beds, and it’s worked surprisingly well.
The pressure output is around 40–50 PSI, which is more than enough for most standard drip tape or emitter systems. I run a basic filter and a pressure regulator downstream just to be safe most of my drip line is rated for 10–15 PSI, so you definitely want to step it down.
Biggest advantage with this type of pump is the simplicity no need to wire in a pressure switch or deal with a separate tank. It’s basically “plug and play,” and as long as you’ve got a reliable way to keep the tank fed (rain catchment, fill from a hydrant, etc.), it’s a solid little system. Sounds like yours is off to a great start with that 100 gallons off just a 1/4” rain.
If you're thinking about using it for drip, I’d say go for it just add a regulator and watch your emitter pressure rating. Should save you a lot of watering hassle.
Having the rainwater tank has made a huge difference in our garden this year. We’ve been watering for the past 4 weeks and the Zucchini and tomatoes have gone wild! It seems we’ve had more rain this summer than previous years, but using the rain water system helped tremendously.
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2005 CATERPILLAR D3G LGP CRAWLER DOZER (A51246)
2005 CATERPILLAR...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
