Rails for Terra Track Dozer
   / Rails for Terra Track Dozer #1
terra track
Sandpoint, ID
Terra Track
Hi,
This Dozer was built in the 50's I believe and is a smaller than a D2. Case bought the product line in the 60's.
I am rebuilding the undercarriage but parts are not available so I am upgrading to Deere 40 pins and bushings which means I have to bore the rails (links) to larger diameters for interference fit of pins and bushings.
Some of the rails are broken.
Does anybody know where I can buy some used rails to replace the broken rails?
   / Rails for Terra Track Dozer #2
Welcome to TBN. :)
   / Rails for Terra Track Dozer #4
Have you tried "Heavyquip"? They may have a complete set of chains that'll run on your rollers and sprockets without having to do all that machining.
Muhammad and
creekbend -- Thank you for the welcome .
pjbci, Thanks for the tip. I sent them and inquiry. However I have already bought the Deere 40 pins and bushings, built a milling machine fixture, and have about 20 hours of machining into the project -- only about 40 hrs to go. I have a lot more time than money but not much time either.
Anyway it will be interesting to see if Heavyquip has anything and for how much.
Thanks again everyone.
   / Rails for Terra Track Dozer #6
Hope you can find some. If not maybe you can weld up your broken links. I have seen people build up on em with welding rods so surely welding on the rails wont cause them too break.
   / Rails for Terra Track Dozer #8
WELCOME to TBN :)
I moved your thread to the Construction Equipment Forum.
   / Rails for Terra Track Dozer #10
Just a thought, but are Deere rails the same pitch?
And then there's the rubber track option.
Go Kart (A53117)
Go Kart (A53117)
300# CLUTCH JACK (A53843)
300# CLUTCH JACK...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
FORD F450 SUPER DUTY TRUCK (A51406)
FORD F450 SUPER...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
