Radio wiring for XR3037HC cab models
   / Radio wiring for XR3037HC cab models #11
I swapped the factory speakers out for some 5 1/4 pioneers with very little triming, then installed the speakers from the top with factory grilles.
[/url]New stereo and speakers by Jason, on Flickr[/IMG]
The sound is decent along with an inexpensive pioneer head unit. I wanted something with Bluetooth to play Pandora from my phone.
I also added a factory matched Carling switch that allows me to turn only the radio on while the tractor is off. So if I'm out doing some chores like raking or stacking wood i can have some tunes
[/url]new switch for radio. allows me to turn just the radio on while the tractor is off by Jason, on Flickr[/IMG]
Jay
   / Radio wiring for XR3037HC cab models #12
OK guys, for those of you installing aftermarket radios in your cabs here is the wiring for the factory plug.
This will be correct for all 3000 series cabs and I suspect the 4000 series cabs will be the same.
Picture 1 shows the 6 pin radio harness from tractor
Pink wire separate from the harness = 12V Battery Hot
Blue w/white stripe = 12V when ign is on
Black = Ground
Light green w/brown stripe = Right Spkr +
White w/blue stripe = Left spkr -
Green = Right spkr -
Red w/blue stripe = Left spkr +
Last thing to plug in would be the antenna wire into the radio
Second pic shows wiring from my radio (may be different colors on yours)
Also attached is a word doc for the above plug pin out.
Thanks for the LS stereo wiring info. Installed my stereo in my XR3135HC tonite and what a piece of cake. Easy. I cut off the odd ball LS connector and wired directly to the stereo connector wires. Used the heat shrink butt connectors.
   / Radio wiring for XR3037HC cab models #13
Where did you get that switch from?
How did you wire it?
   / Radio wiring for XR3037HC cab models #15
How did the 6.5" speakers turn out and how involved to install with the spacers
   / Radio wiring for XR3037HC cab models #16
Give up and use a Blue Tooth headset. In fact, the bautiful, brand new Pioneer unit is still hanging in the cab unused, for years now.
I tried all of the rest of this and decided it was much easier. Maybe even better quality sound applied directly the audio receiver {My Ear}.
Plus I get the added feature of being in contact with the rest of the world via the cell phone.
They've got a great feature called sound deadening. "What HST whine?"
Although, the Mrs. gets really upset when, for some unexplained reason, the ringer gets "turned off".
Must be a flaw in the iPhone. "Yeah, Honey. I'll get that thing fixed."
You have a choice to make. Shake your fist at technology as it passes you by or
embrace it in whatever manner you choose.
The choice is yours. Me?
For about $150 I wifi'd the farm. Amazon:{Ubiquiti UAP-AC-M-PRO-US Unifi Access Point (Certified Refurbished)}
Carrier signal is 1-2 bars on a good day.
   / Radio wiring for XR3037HC cab models #17
Yep I pretty much have concluded I'll throw on my Bose noise cancelling headphones and call it a day :)
   / Radio wiring for XR3037HC cab models #18
I was doing some digging on this topic and thought I'd add in case anyone stumbles on it. I put some nice Kicker 5 1/4" in mine. I made some 4 to 5 1/4" adapter rings so I didn't have to cut the headliner and then removed the roof panel to install the backing clips for the screws. Turned out very well and made a night and day difference. If you want low end you'll have to add more, but these look factory and sound great with the Sony head unit.
   / Radio wiring for XR3037HC cab models #19
Looks awesome! Good job!
   / Radio wiring for XR3037HC cab models #20
Good speakers make all the difference in these cabbed tractors. I rock out in mine when mowing the pastures.
2021 Fleco DX140 24in Digging Tooth Bucket Excavator Attachment (A55973)
2021 Fleco DX140...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
