Radio/Speaker Upgrade XR3135HC
   / Radio/Speaker Upgrade XR3135HC #1
scodemike
Monument, CO.
LS XR3135HC
I am thinking of upgrading the Radio and Speaker's in my XR3135HC. I have a couple of questions, do you have to purchase a different pigtail plug to adapt the tractor wiring to a radio w/bluetooth? How do you attach the speakers given the nuts that hold the current ones are not fixed, they fall out when the screws are removed?
Thanks for any help you can provide.
The reason for the question re; the pigtail plug, my JD had to have a VW pigtail adapter plug to work with JD wiring.
   / Radio/Speaker Upgrade XR3135HC #2
Not sure if it is any different with a Bluetooth as I did not put in a radio with one, but I think all you need are constant power, keyed power and ground. Then the wire connectors for the speakers too. I found a video that told which wire was which, but my dealer told me after "you should have called me, I would have told you that". As for the nuts for the speakers, I had bought new speakers and they came with speed nuts that you just slide over the holes before putting the speakers up and screwing thru them.
George
Good idea George on the speed nuts, I forgot about them, have some.
   / Radio/Speaker Upgrade XR3135HC #5
The roof also lifts up like a hood. I haven't done it yet so I can't give you specifics on how.
   / Radio/Speaker Upgrade XR3135HC #6
There are 4 nuts that hold the roof down, one above each door, and one beside each roof light in the front. Don't forget to unplug the wires for the roof lights. Lift up the roof, about 45 degrees. There is a prop rod zip tied down on I think the right side. I never saw a place for the rod to set into so I used a wooden 2 X 2 about 18 or so inches long to hold the roof up.
George
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58216)
2011 NORAM POWER...
VOLVO A25G OFF ROAD DUMP TRUCK (A60429)
VOLVO A25G OFF...
Spreader Attachment (A56859)
Spreader...
