Radio Reception problems
/ Radio Reception problems #1
deere4600
Last summer I mounted an older JD (motorola) fender radio on my 4600 compact. While stationary the reception was adequate. However, when I moved the tractor the reception was poor. I was wondering if the ROPS was blocking the signal when I turned the tractor. The radio has a new antenna and works fine on the garden tractor (no rops). Any thoughts on whether the ROPS is the culprit? If so, any thoughts on a cure?
/ Radio Reception problems #2
By the sounds you have found the problem.
Would the antenna be w/in 10 or 12 inches from the ROPS,also have you tried and relocate the radio for a better signal.
The new antenna would that be rubber coated and somewhere in the area of 8 inches tall,also you can now purchase antenna w/something like a booster in it.
Would the radio be AM&FM...try FM and see if the signal better.
Thomas..NH /w3tcompact/icons/wink.gif
/ Radio Reception problems #3
I mounted a newer radio next to the ROPS of my Kubota. The antenna is about 1 inch from the ROPS and I dont have any reception problems with FM. I have not tried AM. My antenna is the short type with the plastic/rubber coating.
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2013 Caterpillar 420F Backhoe (A64194)
2013 Caterpillar...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2006 MACK VISION (A65643)
2006 MACK VISION...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
