Radio Reception problems
/ Radio Reception problems #1
deere4600
Last summer I mounted an older JD (motorola) fender radio on my 4600 compact. While stationary the reception was adequate. However, when I moved the tractor the reception was poor. I was wondering if the ROPS was blocking the signal when I turned the tractor. The radio has a new antenna and works fine on the garden tractor (no rops). Any thoughts on whether the ROPS is the culprit? If so, any thoughts on a cure?
/ Radio Reception problems #2
By the sounds you have found the problem.
Would the antenna be w/in 10 or 12 inches from the ROPS,also have you tried and relocate the radio for a better signal.
The new antenna would that be rubber coated and somewhere in the area of 8 inches tall,also you can now purchase antenna w/something like a booster in it.
Would the radio be AM&FM...try FM and see if the signal better.
Thomas..NH /w3tcompact/icons/wink.gif
/ Radio Reception problems #3
I mounted a newer radio next to the ROPS of my Kubota. The antenna is about 1 inch from the ROPS and I dont have any reception problems with FM. I have not tried AM. My antenna is the short type with the plastic/rubber coating.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Gehl Mix-All Grinder Mixer (A66408)
Gehl Mix-All...
Bomag Roller (A63689)
2022 EZ-GO ELITE...
Komatsu D65EX Dozer (A66285)
Komatsu D65EX...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
