Radio for L5740
/ Radio for L5740 #2
Any radio works, assuming you are talking about a cabbed 5740. It is far easier to pull the lid of the cab off to do it, but it is supposedly possible from the inside only (but I doubt it, based on what it took me to do it...). You will need to get the harness on ebay (or from a dealer) to connect to the existing harness in the roof of the cab, and then connect the antenna jack to the existing antenna cable.
If you don't have a cab, then ignore all of the above :D
/ Radio for L5740 #3
Northern tool and others make a whole integrated radio / speaker overhead console unit to install. Would help if we knew what you were working with... Cab? Sunshade only?
/ Radio for L5740 #4
Assuming cab like mine, it was plug in installation with a tough radio I bought from Best Buy. I did question the speaker connection, pulled a speaker to insure in my mind I interpreted the wires right - I had but reinstalling the speaker required removing the roof which I found out is very easy. So it was radio (garage sale unit will do), adapter cable from the dealer, and pop into place. Even the radio Kubota supplies requires the adapter cable. My M135GX already had the Kubota option installed but would sometimes lose connection. When I removed the radio to trouble shoot I found it used the same jumper harness I needed for my L5740 and whomever had made the installation had not pushed the plugs together hard enough. So the only thing special is the adapter harness.
/ Radio for L5740
Great thanks for the info found what I need at Farm radio supply
213119 (A64276)
213119 (A64276)
MCCORMICK X4.70 TRACTOR (A64280)
MCCORMICK X4.70...
2025 32in. Tilting Bucket Mini Excavator Attachment (A61572)
2025 32in. Tilting...
UNUSED WOLVERINE HYD MINI STUMP GRAPPLE (A64281)
UNUSED WOLVERINE...
2022 Kubota SVL97-2 Compact Track Loader Skid Steer (A61572)
2022 Kubota...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
