Radiator screen
/ Radiator screen #1
oliver28472
Mt. Ulla, NC
Satoh S-470D, Mitubishi FD 1450D
Every now and then somebody asks about a screen for the radiator. I just had mine rebuilt on the 1450 FD. It was stopped up inside and out and the two side frames where it mounts to the tractor were loose at the bottom. Glad I did this when I didn't have to. This is my dedicated mowing tractor. Sometimes I mow the inside of the fence which causes a lot of weed seeds to get in the radiator. Bought a cut to fit furnace filter and cut it to fit. When the engine is running, the filter sucks right up against the rad.
/ Radiator screen #2
I'm concerned about the restriction and potential for that stuff to melt if its touching the hot radiator....Not the route I would have gone, but keep us posted.
/ Radiator screen
Boy, that would be a mess wouldn't it? The blue stuff only costed about 6 bucks. A 14x14 paper furnace filter will slide in there too. I put a gauge on last year and will be able to watch the temp and will be checking for sure.
/ Radiator screen #4
I agree, Too restrictive. Some of that filter material has oil on it also.:ashamed:
/ Radiator screen
It's not oily to the touch. Now you guys have me thinking I need to drop in the other filter. And thinking about restriction, I would think the cfm being sucked in by the fan would be less than what a house system would pull.
/ Radiator screen #6
If its blue it is oiled. Use some screen.
/ Radiator screen #7
I have an MT327D and I made a radiator screen out of small wood frame (like 1/2"X1/2") and wrapped a screen door screen around it and used a staple gun to secure it. I made it a snug fit so no brackets were needed. I've had it in for well over 8 years with no probles at all. Of course I blow out the radiator after each mow (lawn mowing).
/ Radiator screen
Alvanko, I finally did that too. Got some 1/4" plywood cut down at the store and made one for each tractor. Left about 1" all the way around to staple the screen to. Very easy job.
/ Radiator screen #9
You really have to watch any of the plastic screens, a lot of then do not alow a lot of air flow. Even on a class eight truck a test you want to do on all screens is to run the tractor with the fan engaged if it has a thermatic fan,run it at about 1400 RPM take a water hose and spray it threw the radiator and watch the spray pattern do it right threw the middle. Then install you screen and do it again.
KW use to sell a bug screen for their trucks with teeth on them and it did not allow hardly any air flow threw it, the plastic mesh had very few holes in it.
The test is an easy one.
/ Radiator screen #10
I certainly don't see how this filter can let enough air thru the radiator...The screen barely lets enough thru with-out any trash in it...
/ Radiator screen #11
That is the nice part about testing with a hose and water it costs nothing and you really can see from the spray pattern before and after the restriction.
/ Radiator screen
The blue filter has been trashed, based on recommendations from murphy, so I made the plywood frame with aluminum window screen stapled to it. Should be fine and have plenty of airflow without doing the garden hose test. I have a temp light and gauge anyway.
/ Radiator screen #13
I like your "design" better then mine. I may have to make a new one this summer.
/ Radiator screen #14
If you can find a good metal screen that is the very best, most places do not have metal screens anymore.
/ Radiator screen
Lowes has it. It is aluminum window screen, easy to cut with a plain pair of scissors. If you have a good hardware store that still makes replacement window screens you could probably get only what you need. I bought a small piece of 1/4" plywood at Lowes and they cut it to my specs with their panel cutter. Total cost on the plywood was less than $5 bucks.
/ Radiator screen #16
a good metal screen in front of every radiator is a great idea to keep the bugs out of the coolers and radiators, that works, In this area metal screen is getting hard to find and the plastic stuff is nearly waterproof.
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2001 International 4000 DT 466E (A60462)
2001 International...
IH 1486 Tractor (A66285)
IH 1486 Tractor...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
