radiator heater - plugged in too long?
   / radiator heater - plugged in too long? #1
44trxfun
western NY
MF GC2300
Through a little misunderstanding, my inline radiator heater was plugged in for several (4-6) hours. Somewhere in the back of my mind, I almost remember my dealer warning me not to leave it plugged in for more than 1-1.5 hours. Do any of you folks think I did any harm? Thanks.
   / radiator heater - plugged in too long? #2
Worst case could have been to boil your water and blow it out the radiator cap, then fry the heater. If you still had water, no harm, no foul.
   / radiator heater - plugged in too long? #3
For the most part it shouldnt have hurt a thing. Here in Wisconsin Car heaters are left in all night . Up to 12 hours at times.
   / radiator heater - plugged in too long? #4
I picked up somewhere that after two hours your engine block will not get any hotter than it already is. This was for a pickup though (If'n I don't have my wires crossed). If the block heater was larger than would be prudent for the size of your engine, then maybe a boilover could occur?
   / radiator heater - plugged in too long? #5
The block heaters have a thermostat control and will maintain a constant temperature. Plug it in as long as you like - no harm - just power bill.
Egon /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / radiator heater - plugged in too long? #6
Yeah like Egon has it right, there is a thermostat in them to turn them off when they get too hot. I wouldn't worry about it at all. We use to leave them plugged in all night on our diesel trucks.
murph
</font><font color="blue" class="small">( The block heaters have a thermostat control and will maintain a constant temperature.)</font>
My question was actually about an inline radiator heater, but I do appreciate the responses.
   / radiator heater - plugged in too long? #8
Most inlines that I have seen have a thermostat built in them just like block heaters. The heater itself has to be protected or you would burn it out also if left on too long.
murph
   / radiator heater - plugged in too long? #9
I haven't seen a block heater with a thermostat. The ones I have seen are just a simple heating element like the one in an electric hot water heater. When plugged in and working properly the generate a constant heat output until unplugged.
Dave
   / radiator heater - plugged in too long? #10
I doubt they have thermostats. What happens is that heat losses equal to heat input by these small heaters after an hour or so.
I'd put it on a timer. Just have it come on about an hour before you need it.
Ralph
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51691)
2003 International...
Krause Dominator 4850-18ft (A53473)
Krause Dominator...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
Unused Delta Crash...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
