radiator heater - plugged in too long?
   / radiator heater - plugged in too long? #1
44trxfun
western NY
MF GC2300
Through a little misunderstanding, my inline radiator heater was plugged in for several (4-6) hours. Somewhere in the back of my mind, I almost remember my dealer warning me not to leave it plugged in for more than 1-1.5 hours. Do any of you folks think I did any harm? Thanks.
   / radiator heater - plugged in too long? #2
Worst case could have been to boil your water and blow it out the radiator cap, then fry the heater. If you still had water, no harm, no foul.
   / radiator heater - plugged in too long? #3
For the most part it shouldnt have hurt a thing. Here in Wisconsin Car heaters are left in all night . Up to 12 hours at times.
   / radiator heater - plugged in too long? #4
I picked up somewhere that after two hours your engine block will not get any hotter than it already is. This was for a pickup though (If'n I don't have my wires crossed). If the block heater was larger than would be prudent for the size of your engine, then maybe a boilover could occur?
   / radiator heater - plugged in too long? #5
The block heaters have a thermostat control and will maintain a constant temperature. Plug it in as long as you like - no harm - just power bill.
Egon /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / radiator heater - plugged in too long? #6
Yeah like Egon has it right, there is a thermostat in them to turn them off when they get too hot. I wouldn't worry about it at all. We use to leave them plugged in all night on our diesel trucks.
murph
</font><font color="blue" class="small">( The block heaters have a thermostat control and will maintain a constant temperature.)</font>
My question was actually about an inline radiator heater, but I do appreciate the responses.
   / radiator heater - plugged in too long? #8
Most inlines that I have seen have a thermostat built in them just like block heaters. The heater itself has to be protected or you would burn it out also if left on too long.
murph
   / radiator heater - plugged in too long? #9
I haven't seen a block heater with a thermostat. The ones I have seen are just a simple heating element like the one in an electric hot water heater. When plugged in and working properly the generate a constant heat output until unplugged.
Dave
   / radiator heater - plugged in too long? #10
I doubt they have thermostats. What happens is that heat losses equal to heat input by these small heaters after an hour or so.
I'd put it on a timer. Just have it come on about an hour before you need it.
Ralph
2021 Ford F550 XL 4x4 Service Truck (A52384)
2021 Ford F550 XL...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
BS 600 Jumping Jack (A52384)
BS 600 Jumping...
