Radiator for Iseki Landhope TU200F
   / Radiator for Iseki Landhope TU200F #1
nelval
West Newbury, MA
My tractor (diesel, 20 HP, 3 cylinders) has a small leak on the radiator. Took it to a radiator repair shop and they want $445 to build a new core. Is there a place where I can buy a new or used (working) radiator for less? -Nelson
   / Radiator for Iseki Landhope TU200F #2
You can use radiator repair liquid. Like this Liquid Copper
I use for may Iseki TU180 and work great. Its keep closed radiator leak two years and no more new leaks.
   / Radiator for Iseki Landhope TU200F #3
Of course I have no way of knowing where your leak is but I just soldered a leak in my ( Mitsubishi's) radiator. A little investigating revealed the core was copper. I simply cut away a small section of fins to reach the hole and used a small propane torch and flux core plumbing solder......gently heated the area around the hole until it was hot enough to melt the solder and ran a little over the hole/area. Fast, easy, cheap and worked great. I was going to try Bar's Leaks but had the solder on hand and wanted to get it done and knew it would work. I too have used Bar"s Leaks in the past for small automotive leaks with success.
Year: 2011 Make: Kia Model: Forte Vehicle Type: Passenger Car Mileage: 172,391 Plate: Body Type: 4 (A51694)
Year: 2011 Make...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
UNUSED RAYTREE RPRB72-72" RAKE BUCKET (A51248)
UNUSED RAYTREE...
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
JOHN DEERE 7R210 LOT NUMBER 49 (A53084)
JOHN DEERE 7R210...
