Radiator for Iseki Landhope TU200F
   / Radiator for Iseki Landhope TU200F #1
nelval
West Newbury, MA
My tractor (diesel, 20 HP, 3 cylinders) has a small leak on the radiator. Took it to a radiator repair shop and they want $445 to build a new core. Is there a place where I can buy a new or used (working) radiator for less? -Nelson
   / Radiator for Iseki Landhope TU200F #2
You can use radiator repair liquid. Like this Liquid Copper
I use for may Iseki TU180 and work great. Its keep closed radiator leak two years and no more new leaks.
   / Radiator for Iseki Landhope TU200F #3
Of course I have no way of knowing where your leak is but I just soldered a leak in my ( Mitsubishi's) radiator. A little investigating revealed the core was copper. I simply cut away a small section of fins to reach the hole and used a small propane torch and flux core plumbing solder......gently heated the area around the hole until it was hot enough to melt the solder and ran a little over the hole/area. Fast, easy, cheap and worked great. I was going to try Bar's Leaks but had the solder on hand and wanted to get it done and knew it would work. I too have used Bar"s Leaks in the past for small automotive leaks with success.
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A53472)
UNVERFERTH 330 -...
2012 CASE IH 1230 LOT NUMBER 186 (A53084)
2012 CASE IH 1230...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
FRONTIER AH11G LOT NUMBER 112 (A53084)
FRONTIER AH11G LOT...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A52576)
2023 PETERBILT 579...
