Radiator fan shroud missing
/ Radiator fan shroud missing #1
Ben755
Tx
Yanmar FX28D
I replaced the water pump on my FX28D and forgot to put the fan shroud back on. I think I can just loosen the radiator connections enough to slip the shroud back between the
radiator and fan., But I'm wondering if the shroud is really needed - it seems that the radiator and fan would actually get more air from the side vents without the shroud, and the
fan side of the radiator would definitely have easier access for cleaning - any thoughts on this ?
/ Radiator fan shroud missing #4
If it wasn't needed, manufacturers would drop it like a hot potato. They cost too much to just put them on for nothing. You need the shroud! :cool:
/ Radiator fan shroud missing #5
^^^^^ditto
/ Radiator fan shroud missing #7
You need the shroud to direct the airflow thru the radiator.
Its a safety issue, too. Open a hood with an engine running and the fan shroud missing and get too close, that fan'll rip your shirt off.
Thanks for the responses - I guessed that the shroud might be necessary, but wanted to be sure.
/ Radiator fan shroud missing #10
Anybody remember the first generation flathead Fords? The distributor was below and behind the fan. Setting timing could be brutal.
I think 9N's were like this too.
/ Radiator fan shroud missing #11
Dad lost half his pinky that way.
/ Radiator fan shroud missing #12
I thought that probably wasn’t important on my truck after got done changing a water pump. Nope, it overheated within a few miles.
/ Radiator fan shroud missing #13
So is my 49 8n BUT same as a 2n and 9n, the timing is set on the bench w the distributor removed from the tractor so not so brutal
/ Radiator fan shroud missing #14
A few of my timing lights show the fan marks. Some models of car are near impossible. Seen a few guys lift the car and take the front wheel off the front wheel drive land yachts. First of the Taurus I believe. Crazy.........
/ Radiator fan shroud missing #15
In cold weather startup, the shroud also acts as a pre-heating conditioner grabbing warm air off the engine thru the radiator to turn the slush anti-freeze back to a full liquid. It could help you in TX as the ice-age moved in there this year. :p
/ Radiator fan shroud missing #16
When i was an apprentice mechanic over 40 years ago, I left the fan shroud off the company's delivery van as it was a huge pain to get on and off and I was the only person servicing the thing regularly. The delivery driver couldn't complete his rounds the next morning cos the thing was overheating. I got a well-deserved reaming but learned why the shroud is there.
JOHN DEERE 4760 TRACTOR (A64280)
JOHN DEERE 4760...
Sprayer (A64119)
Sprayer (A64119)
2019 ATLAS COPCO XAS 185 PORTABLE AIR COMPRESSOR (A64279)
2019 ATLAS COPCO...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A61572)
2025 BrushFox...
2021 Harley-Davidson FLHP Road King Motorcycle (A61574)
2021...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
