Radiator Fan : Should I replace
/ Radiator Fan : Should I replace #1
drjay9051
Morriston, Fl. 40 miles west of Ocala. More cows
Kioti DK 40 HST
Well I did something stupid!
Had the right side engine cover off as I was doing a complete tractor cleaning.
In the middle of cleaning I helped a neighbor move some brush without replacing cover.
A small branch hit the fan behind the radiator and all the blades now have a small area broken off.
Tractor does not overheat. Should I pay to have fan replaced or consider myself lucky that the blades were not totally destroyed and leave it alone.
Of course replace covers next time before tractor work.
/ Radiator Fan : Should I replace #2
It depends on how much is broken and if all the blades are broken to the same degree so it is still balanced. If it is just a small amount and all equal, I think I might just run it for a while as is.
In any case, I wouldn't pay hundreds of $$$ to have it replaced, do it yourself, it cant be that hard to do with just nominal tools on hand.
/ Radiator Fan : Should I replace #3
I would replace it. The blade may be out of balance enough to cause the waterpump to wear due to vibration. Looks like its easy enough to change.
/ Radiator Fan : Should I replace #4
I was grubbing in the woods a few years ago and backed up over a stick that quickly removed all of my fan blades. A replacement fan is pretty cheap and there is just enough room to get the old one out and the new one in without removing the radiator or fluid.
Mayrath 10" x 30' Truck Auger (A66285)
Mayrath 10" x 30'...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
207923 (A63290)
207923 (A63290)
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
3098 (A63117)
3098 (A63117)
