radial tires and liquid ballast
   / radial tires and liquid ballast #1
john12566
2032r
Will be trading down to a new Deere 2025r and wanting to get the Galaxy radial tire option. Will have a loader on the tractor and have always had liquid ballast in the rear tires for that reason. A lot of info out there--much of it from tire manufacturers themselves--saying not to load radial tires. I read more than once that loading a radial tire basically "turns it back into a bias ply tire."
Anyone out there that has loaded (liquid) radial tires and could share their experience with the ride, footprint and soil compaction, especially if they have a before and after experience?
Thanks.
John
   / radial tires and liquid ballast #2
In regards to the radial issue. I've never heard that. My [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] has Titan radials with the rears filled. I have no complaints about the performance.
"turning it back into a bias ply tire" would indicate a loss of traction maybe? Not sure what that means. The footprint of mine is just as pliable as when they were unloaded. There might be a bit harsher ride because of a smaller air bubble in the tire. But certainly not enough that I notice it.
My little 2210 has bias ply tires. I loaded the rears and ran it that way for several years. When I moved the duties of that tractor changed. Less compaction became more important than added traction. I dumped the fluid. For MMM duties I think it actually rides a bit worse without the fluid.
If using an FEL the weight gain offsets any losses.
   / radial tires and liquid ballast #3
I loaded my rear radial tires.
I noticed the water stiffened the ride but not as stiff as my old bias ply tires.
   / radial tires and liquid ballast #4
I'm not familiar with your size tires but I don't recall seeing that info before on the larger tires I'm more familiar with.
We don't like liquid fill for many reasons, we prefer bolt on iron ballast.
That said I don't see were liquid fill would be affecting the tire performance as too making a radial behave like a bias ply.
We much prefer the radials on tractors for the traction and slightly better compaction, they do allow more sway from the tires on steep sidehills.
Again this info is coming from some of the maufacturers, not me
   / radial tires and liquid ballast #6
Yep we understand. We're just offering our experiences.
With an FEL on that tractor I'd want some sort of tire/wheel weight.
I agree with Lou's thoughts comparing cast iron weights to tire fluid. The only advantage fluid has is initial cost. My [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] has fluid plus cast iron weight. I still carry a heavy box blade on the 3pt when doing heavy Grapple work.
AG tractors carry a much larger percentage of their total weight on the rear tires. Utility tractors are a bit more balanced. CUTS and SCUTS carry a much larger percentage on the front.
Welcome to TBN!!! Let us know what you decide. With pictures of the new tractor of course.
   / radial tires and liquid ballast #7
Have radials loaded with Calcium. Loader tractor so weight is desirable. Came that way from dealer.
   / radial tires and liquid ballast #8
Radial tires with a tube.
   / radial tires and liquid ballast #10
Reason I was told to consider steel weight vs fluid in radials is the fluid slows down how quickly the radial can flex and absorb bumps or follow ground contour. Per the tire supplier this could possibly damage the radial tire easier that bias ply but not sure what operating conditions or speeds this was based on. I suspect concern is With more farmers operating at higher speeds of 8 - 10 MPH. He did not mention concerns about traction loss.
This information is also around 5 years old so tire designs may have changed since then.
8ft Disc Mower (A57454)
8ft Disc Mower...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2020 Chevrolet Tahoe SUV (A56859)
2020 Chevrolet...
Makita Impact Drill with Charger (A57454)
Makita Impact...
