R4047 with Error Code B36
   / R4047 with Error Code B36 #1
mjflath
Escanaba, MI
LS R4047EZ
Hi Folks,
I have a R4047 that just threw a B36 error code. I'm not able to find a description for that one and the local dealer hadn't run into it before. Does anyone know what that error code indicates?
Thanks much!
   / R4047 with Error Code B36 #2
My tractor is different than yours. But I was hoping that maybe the codes were similar. I looked up my manual and did not see your error code.
Is the tractor behaving differently? Do you have a scan tool?
Behavior is the same as best I can tell - no issues with forward/reverse shifting via the shuttle or movement; just the B36 and beeping. B35 is the last entry in the manual which is the reason for reaching out here. I do not have a scanner so a trip to Harbor Freight may be in order.
   / R4047 with Error Code B36 #4
This is the scanner that I use for my tractor
Amazon.com: Elm327 Launchh OBD2 Professional Bluetooth Scan Tool and Code Reader for Android,ELM327 V2.1 Interface OBDII OBD2,Car Auto Diagnostic Scanner,Not Support J185 VPW and J185 PWM Communication Protocol: Automotive
Not all scan tools are the same. I have a really expensive scan tool (that I honestly never use) and the Blue Driver scan tool (which is my go to for all my vehicles). Both of those dont work for my tractor. I had to buy a $10 tool to read the codes from my tractor. :confused3:
Just FYI.
Please keep us posted as to what you found.
   / R4047 with Error Code B36 #5
Just FYI.
I think you posted in another thread what app you use with that ELM327 reader but I can't find it. Can you post it again or a link to that post?
   / R4047 with Error Code B36 #6
Its called Torque. I think there is a lite version (called Torque Lite) that is free. I dont remember what the price tag was on the paid version, but it wasnt horrible. Works well!
   / R4047 with Error Code B36 #7
   / R4047 with Error Code B36 #8
I believe it is a tm speed sensor (for the transmission if I recall correctly?) ... had to do with the ez shift - I do remember there was a recall for some ez shift issues but not sure if this was one of them?
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2021 FREIGHTLINER...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 72"...
2020 KUBOTA RTV...
International 1086 Cab Tractor 2wd (A52128)
International 1086...
UNUSED FUTURE SKID STEER QUICK ATTACH MULCHER (A51244)
UNUSED FUTURE SKID...
