R4047 with Error Code B36
/ R4047 with Error Code B36 #1
mjflath
Escanaba, MI
LS R4047EZ
Hi Folks,
I have a R4047 that just threw a B36 error code. I'm not able to find a description for that one and the local dealer hadn't run into it before. Does anyone know what that error code indicates?
Thanks much!
/ R4047 with Error Code B36 #2
My tractor is different than yours. But I was hoping that maybe the codes were similar. I looked up my manual and did not see your error code.
Is the tractor behaving differently? Do you have a scan tool?
Behavior is the same as best I can tell - no issues with forward/reverse shifting via the shuttle or movement; just the B36 and beeping. B35 is the last entry in the manual which is the reason for reaching out here. I do not have a scanner so a trip to Harbor Freight may be in order.
/ R4047 with Error Code B36 #4
This is the scanner that I use for my tractor
Amazon.com: Elm327 Launchh OBD2 Professional Bluetooth Scan Tool and Code Reader for Android,ELM327 V2.1 Interface OBDII OBD2,Car Auto Diagnostic Scanner,Not Support J185 VPW and J185 PWM Communication Protocol: Automotive
Not all scan tools are the same. I have a really expensive scan tool (that I honestly never use) and the Blue Driver scan tool (which is my go to for all my vehicles). Both of those dont work for my tractor. I had to buy a $10 tool to read the codes from my tractor. :confused3:
Just FYI.
Please keep us posted as to what you found.
/ R4047 with Error Code B36 #5
Just FYI.
I think you posted in another thread what app you use with that ELM327 reader but I can't find it. Can you post it again or a link to that post?
/ R4047 with Error Code B36 #6
Its called Torque. I think there is a lite version (called Torque Lite) that is free. I dont remember what the price tag was on the paid version, but it wasnt horrible. Works well!
/ R4047 with Error Code B36 #7
/ R4047 with Error Code B36 #8
I believe it is a tm speed sensor (for the transmission if I recall correctly?) ... had to do with the ez shift - I do remember there was a recall for some ez shift issues but not sure if this was one of them?
UNUSED INDUSTRIAS AMERICA F08T-8' LAND LEVELER (A62130)
UNUSED INDUSTRIAS...
Winchester Gun Safe (A61166)
Winchester Gun...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
Bradco 84in Hydraulic 6-way Dozer Blade Skid Steer Attachment (A61567)
Bradco 84in...
1985 Mack RW713 Superliner Tri-Axle Heavy Haul Truck, VIN # 1M2AY11Y6FM001206 (A61165)
1985 Mack RW713...
(APPROX.100) UNUSED KJ 10' HD GALVALUME STEEL (A62131)
(APPROX.100)...
