R1's for 4300
/ R1's for 4300 #1
Branch
Temecula, CA
4300 JD, Sync Shift
R1\'s for 4300
I have a new 4300 with R4's. My property is very steep in places and also very rocky. My dealer suggested R4's for durability but I just read on another website that the R1's can be moved much further out for stability. Should I change to R1's? If I do what will I be sacrificing?
/ R1's for 4300 #2
Re: R1\'s for 4300
The only thing I can think of is the R1s are going to tear the ground a little more. If you are using it to mow with that might make a difference. I think I have read here that the R4s are more durable, maybe somebody else knows for sure. Have you put fluid in your tires? That may help stabilize it somewhat.
/ R1's for 4300 #3
Re: R1\'s for 4300
Branch
I think the R-4s are a heavier duty tire than the R-1s. The ones I have seen are 6-ply rating on the R-4s and 4-ply on the R-1s. If you use a loader, backhoe, or other heavy implements you might want to stay with the R-4s. The R-4s also should be more puncture resistant than the R-1s. If you use a mid-mount mower be sure that the R-1s don't interfere with the deck if set in a wider position. I think the R-1s are larger in diameter than the R-4s so any stability gained by setting them wider would be partially offset by raising the center of gravity of the tractor./w3tcompact/icons/frown.gif I am planning to buy a 4300 with 430 loader, 48 backhoe, and mid-mount mower and I will be getting the R-4s. I don't have any steep hills on my land though. Good luck. MJB
/ R1's for 4300
Re: R1\'s for 4300
I won't be doing any mowing, but have lots of loader and scraper work to do. I do have a lot of sharp rocks, brush etc.. The rear tires are filled. It sounds like the salesman was right. Thanks for the input.
/ R1's for 4300 #5
Re: R1\'s for 4300
Branch I have a JD 990 4wd,my dealer talked me into the R-4s.I thought the R-1s would be better.I now have 13 hours on tractor and brush hog in terrain much like yours.My dealer suggested that I have the tires loaded.All i can say is that he was right on both counts.The R-4s are a tough tire that do a good job at many tasks.Stay SAfe BILLG
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
207269 (A52708)
207269 (A52708)
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A64279)
2000 CATERPILLAR...
