R F Modulator question
/ R F Modulator question #1
tallyho8
Super Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
My barn is 1/4 mile from my house on my property and years ago I installed a surveillance camera in my barn so I could keep an eye on my pregnant mare and I ran coax cable to a small tv in my house. The camera hooked up to an RF Modulator that you could set to watch it on either channel 3 or 4.
Now I would like to set up another camera in my barn using the same coax cable which is buried. I tried getting another RF modulator using a splitter and setting one camera for channel 3 and one for channel 4 so I could just change the channel on my tv to see either camera. Of course having the channels this close together gave bleed-over making the picture fuzzy. Just like in the old days when you could only get channels 2, 4, 6, 8, 10 and 12 because any channel in between those would interfere with the channel next to it.
My question, is there any type of Rf modulator sold that gets channels other than 3 and 4? If not, does anyone know a cheap fix to get these cameras working correctly.
/ R F Modulator question #2
Wifi cameras?
I had some but my 1000metres was a bit too long, not sure what the range is on them now.
/ R F Modulator question #3
Hopefully an electrical engineer will chime in (I'm an ME) but I am pretty sure you could slightly modify the components inside the RF modulator to customize the frequency, to bump it away from 3/4. They are very simple devices, I remember using and modifying them back in the 1980s for video games and VCRs. Always thought it was a cool idea.
There are some on Amazon that claim to support multiple frequencies and even UHF -- maybe that is an easier option?
https://www.amazon.com/Modulator-KKmoon-Compact-Converter-Amplifier/dp/B079JXQKQJ
/ R F Modulator question #6
Moral of story... Don't start down the road of old technology. While we have come up with some UHF RF modulators that will likely solve your problem, a better solution for anyone starting out and needing a solution of a distant outbuilding camera is to use an IP camera to start with. With wifi for a link between the outbuilding and the viewing building. With and IP camera system you are not limited by the number of "channels" you would be able to find an RF modulator for as RF modulators are an old dying technology. Also with IP cameras and wifi as the link you avoid the lightning strike threat of having copper cable (the coax) in the ground. IP cameras are cheap, readily available and are controllable for tilt pan and zoom all over the IP network. This is the way I would start to build out a camera network in this modern age. And you can have as many of them as you want and give them seperate IP addresses.
/ R F Modulator question #7
I suspect you'll find both cameras produce composite video. Some of the old computer monitors worked with composite video as an input. The RF modulator took in the composite video and put it onto a carrier at channel three or four (your choice). It sounds as though you are combining these two composite signals and feeding them both into one modulator. You've already figured out you can't do that very well. Each camera needs its own modulator. The television can't separate them because you're putting them onto the same channel. Wireless cameras may be an option but I don't know your budget or how far they transmit. There are also internet cameras but they depend upon a nearby internet connection, be it a bridge or a router. There's nothing really wrong with the old technology - properly applied.
/ R F Modulator question #8
As Dudley has found out, the reason for the channel 3 OR 4 switch on the old RF modulators was so you could AVOID your local channel 3 OR 4. As the FCC never put a channel 3 AND a channel 4 in the same service area. The reason for this is possibility for them to interfere with each other being adjacent AND the RF field strength not being controlled like they are on a cable closed system. Dudley has run into this problem of trying to put ONE rf modulator on channel 3 an Another ONE on Channel 4. As these are the only two choices he has with the equipment his has available. Of course there are other RF modulators available on different channels as we and others have pointed links at. But still the technology is old and there are just better ways of doing things if one was starting out to build a camera network. And that better way of doing things is IP cameras.
/ R F Modulator question #9
Keep in mind, I am not saying for Dudley to scrap his present installation, no far from it. He already has money put into the cameras, the underground cable and the existing RF modulators. In fact if it was me, I would possibly even for reasons of economy be looking at building some RF "pads" to pad down the signal strength out of the existing RF modulators to allow the channel 3 and channel 4 to possibly co-exist and have a balanced level on the same coax. But this requires skills and or finding pre built level pads which may cost more than just buying a second RF modulator for UHF channels. All I am saying is if someone else is considering a multi camera installation than IP cameras are the way to go starting out.
/ R F Modulator question #10
It has been too many years to think clearly on this, but I think the RF modulators might need to be at the camera end to send the signal down the coax on separate channels.. but I really don't know. You would need a convertor for the connector on house end to hook to tv, but not a modulator..
/ R F Modulator question #11
He has his modulators at the camera's end. He is creating channel 3 and channel 4 RF and sending it down the coax. But his is having problems of interference in his TV and the viewing end. He is not trying to send composite video down the coax.
/ R F Modulator question #12
Is there a cheap way to send signals down the cable digitally? But then you’d have to convert it back and separate at the house end.
/ R F Modulator question #13
:banghead:
:laughing:
/ R F Modulator question #15
Never mind!.. :)
/ R F Modulator question #16
Of course such things to send ethernet down coax exist. BUT none of this is going to be a cheap solution for Dudley. Getting an RF modulator on a different frequency is going to be the cheap solution. yes there is a modem to send ethernet down just about every medium ever thought of on earth. But none of these modems are particularly cheap, at least as compared to an RF modulator. There are fiber drivers, twisted pair drivers, single WIRE drivers, Single fiber drivers, and yes even coax drivers. In my career as an Engineer I often had to look for exotic devices to retrofit some application to some existing thing the customer had in place, and you better believe I often scoured the web to find these obscure devices. But if I was building something "greenfield" Meaning starting out fresh, I always looked for the cheapest and most modern technology starting out. Something that would be supported in the coming years was high on my list of "gotta haves".
/ R F Modulator question #17
I like old school, robust, stand alone technology. I once connected a modulator being fed from a front door camera into the CATV system of a home. Tune to the channel on any TV in the house to see the front door, just like an apartment building. Used a RF modulator but not sure what I used to inject the signal into the CATV system. I think I had help from a friend who owned the local Cable company. Heck, the Cable companies put hundreds of channels on one coax, so putting two on one coax is no problem. The OPs modulators were probably just too close and of poor quality.
No shortage of "cheap" old school TV technology on E-bay.
/ R F Modulator question #18
Your cable company friend likely adjusted the RF level on the coax for you by inserting the proper pads to keep from developing front end overload issues on the TV receiver. Likely Dudley's current setup could be adjusted in the same manner. But having a technician come by and measure the RF signal levels and adjust them with the properly terminated pads of the proper impedance would probably be a lot more of a problem than getting another RF modulator in the UHF spectrum and just slapping that on.
/ R F Modulator question #19
A digital set top box, we used to use one for each channel when putting in repeaters or for MATV in motels etc.
And saw a reference to a 'PAD', is this an attenuator? if so they are quite cheap and have a specific value and F connector.
/ R F Modulator question #20
Yes, Pad = attenuator..
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
2017 CATERPILLAR 335FL CR EXCAVATOR (A65056)
2017 CATERPILLAR...
2006 MACK CHN613 (A67714)
2006 MACK CHN613...
2021 Komatsu PC210L Hydraulic Excavator (A66734)
2021 Komatsu...
2020 Chevrolet Tahoe (A68183)
2020 Chevrolet...
THREE METAL FRAMES (A68842)
THREE METAL FRAMES...
