R-4010 safety flasher switch
/ R-4010 safety flasher switch #1
Short Game
Sunny SW Washington
LS R4010 & Cub Cadet 7300
Hi, long time no see.
Busier than a one armed paper hanger these days.
When I got my R-4010 it had been sitting out at the dealer, in the weather at the coast, and had several corrosion related issues (serious rust in starter and loader valve controls). Since I got it, it has been under cover. One issue was the safety flasher switch. It always was very hard to get the rocker switch into the perfect position to work the flashers. I assumed it was another corrosion issue. Well, it finally got so bad that I couldn't get it to work at all. At the same time, the turn signals quit working.
I removed the left dash panel and found that the problem has always been that the notch that holds the switch together on one side was broken, removing pressure from the switch contacts. There was a corrosion issue as well, as the lower blades and slots in the plug were green and one of the blades was all but rotted off, though still barely hanging on.
I never worried much about the switch, assuming it was a simple switch that could be replaced at any time with any parts store replacement. Not so. The switch has 9 pins and is intricately involved with the turn signal circuits. So, I need this switch and possibly the plug too. Sadly, I am not doing anymore business with the dealer who sold me the tractor. They burned me for $1200 on a used implement and have had two years to make it right and are not interested in making it right, not honoring an agreement with me to make it right. So, I'm done with them. (It's a long story for another time.)
In the Parts Manual it is listed as: SWITCH-EMERGENCY-TRG 750, HMC 181767, and Part Number 40007188.
So, can I get some help here?
I hope everyone here is doing all right.
While my long game is suffering from advancing decrepitude, my short game is holding up.
/ R-4010 safety flasher switch #2
You can go to partsforlstractors.com and look up the price. if not listed call the number and they can order it and have it shipped to you.
/ R-4010 safety flasher switch #4
This dealer has one in stock. Griffin Farm Equipment 662-837-7676 Ripley, Ms. 38663 Price is $80.00
I'm going to hold off for a bit after discovering that the good folks at partsforlstractors.com think it should cost over $20 in freight to move a small part weighing less than 1.2 oz. That's what it weighs if they include the semi-transparent dust cover.
I figure to come up with an alternate switch plan if I can.
Going to bump this as it pertains to my other electrical issue thread. This will explain the $65 cost I mentioned there.
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
27in. MB27 Hydraulic Concrete Mixing Bucket Mini Skid Steer Attachment (A59228)
27in. MB27...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
