Quick welding question
/ Quick welding question
I'm MIG welding with a Millermatic 251, using .045 wire. It's spec'd to handle up to 1/2" at one pass and it doesn't seem to be having any trouble doing that. I'll be welding 1" anchors, but will be able to do fillets on both sides and ends so, with a small bevel groove all round their base, the anchors should be OK.
/ Quick welding question #12
Mad.
Sorry about the confusion (on my part). For some reason I though you had to weld the cylinder mount itself...not realizing it has tie rod ends.
In any case, decently penetrating welds should easily hold the mounts your talking about. They're going to be located fairly close to the cylinder and it's not like you've created a lever, to pry the welds apart, more like it would have the shear the welds.
/ Quick welding question #13
What gas are you using? C25 is not the greatest for penatration. 98/2 with your machine cranked up would make the weld bite in pretty good in the flat position. You could go with a little roll or flux core and get nice penatration too and have the out of position versatility, but you do have some splatter and slag to deal with.
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
John Deere 1025R (A53317)
John Deere 1025R...
TraxMax Stand-On Tracked Sod Installer (A59228)
TraxMax Stand-On...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2014 American Signal Solar Towable Message Board (A59228)
2014 American...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
