Quick Hitches Quick Hitch???
/ Quick Hitch??? #2
If you perform a search on quick hitch you will find lots of discussions on them.
In general they work fine. All my stuff will work but there are a number of implements that need to minor modifications to fit the QH.
/ Quick Hitch???
I have heard that there are other manufacturers of this same design. Does anyone know who else make it?
I called the local John Dealer and they make one but the salesman did not recommend it.....kinda strange for a salesman...don't you think?
/ Quick Hitch??? #4
I think the ones TSC have are the Speedco units. Looks the same as the one at NT.
/ Quick Hitch???
Thanks for the replies......I went to Northern and they had one in stock but it did not look right.....something told me not to buy it.....so I didn't. I then drove to TSC and they had one and I realized what was wrong with the Northern one. It was missing several parts and was $30 more than the one at TSC. I bought the one from TSC and will try it out this weekend.....
Thanks again.
/ Quick Hitch??? #6
Agood,
What are you putting it on? Does not work withsome CUT's.
Your profile does not mention any kind of tractor.
/ Quick Hitch??? #7
I've got the John Deere version (iMatch) and I love it.
I am adapting my none iMatch compatible attachments
No more smashed fingers and / or back problems
/ Quick Hitch??? #8
The salesman might just be a heads up guy that felt like
doing you a favor.
I think there may be either a patent issue involved or
extreme arrogance on JD's part to think that people are
only going to run out and buy brand new IMatch compatible
attachments.
Even some of JD's stuff won't work with it.
So you would think if they could they would just build
their quickhitch like the Landpride built model that has
an adjustable top position.
With that your range of old and new implements that can be
used without modifications is much larger.
The JD top position is fixed.
/ Quick Hitch??? #9
I went with the Land Pride Quick Hitch. The reason I chose Land Pride over the other ones on the market was the top hook is adjustable. I have some Land Pride equipment which was not set up for the hitch and called Land Pride for the spec's to drill new top pin holes. I also have some equipment which could not be modified and the adjustable top hook gave me use of these implements also. Works fine end of story.
/ Quick Hitch??? #11
New Holland as well as a few others I am shure use a 3-point setup that has retractable/extendable lower arms for easy hookup of any implement. I use them and its easy to back up to the implement and then extend the lower arms to align the eyeball sockets without lifting the implement. I am sure they are a site cheaper than the devices shown.
/ Quick Hitch??? #12
I was able to play with mine today and was impressed with how quick i could attach and detach. the only thing i had to was use the adapter for the top link. my implements quick hitch bolts were to far back to use the hook. i think with a little adjustment it will work.
my biggest thing i wanted one was for when i am doing food plots. i can change from my plows to discs alot quicker now. my son will be happier. /forums/images/graemlins/grin.gif
For $89.00 dollars i think it was worth it. now i will just have to see if holds up to heavy use.
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
CHEVROLET C-60 GRAIN TRUCK (A63291)
CHEVROLET C-60...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
