Quick Hitch
/ Quick Hitch #1
Jw5875
NW Pa.
Kubota L3400
I am deciding to buy one, any recommendations?
Thanks,
jw5875
/ Quick Hitch
Well, does anyone have one of these, or is it something from tractor Dreamland?
jw5875
/ Quick Hitch #3
Landpride makes one that seems to be of pretty good quality, and fits as many attachments as most. Pat's easy change also has a strong following here on TBN.
/ Quick Hitch #4
I went "el cheapo" from Harbor Freight and it works OK for me.
/ Quick Hitch #5
The most important part is to make sure that the hitches on your equipment are the correct width for the unit that you are looking at. Some hitches might require some modication on older equipment to hook easily.
/ Quick Hitch #6
I tried the Harbor Freight type and it won't work with my bush hog or mower.
I bought the Pat's Easy Change and am pretty happy with it. Be aware that Pat's Easy Change will extend the length of your lower 3ph arms which changed the geometry of the 3ph.
I have the C&C TopNTilt (which is great) but with the top link (ram) at full extension it does not push the top of the implement as far backward as I need it to. I discovered that when I could not tilt my box blade as far backward as I wanted to. I was only on the tractor for a few minutes after I found that so I haven't had time to see if there is a way to correct the alignment.
I may have to see about a longer ram for the top link as a last resort.
I still have the Harbor Freight quick hitch and if anyone wants to drive to Jasper, Texas and pick it up I will give it to them for free to get it out of my garage. Sorry, I won't ship it under any circumstances. If you want it PM me.
New/Unused Wolverine Quick Attach Hydraulic Concrete Chute (A65583)
New/Unused...
213097 (A64276)
213097 (A64276)
Shell Gas Pumps Yard Art (A64557)
Shell Gas Pumps...
2019 Mercedes Sprinter 2500 Cargo Van (A64556)
2019 Mercedes...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
4' Barnwood Bar Table (A66408)
4' Barnwood Bar...
