Quick Hitches Quick Hitch?
   / Quick Hitch? #31
I actually need to add an additional hole on the flat bar. For the money and the relative little modification I can't complain. I'm sure there are probably better quality pieces out there but they cost at least 3 times the amount. For my uses it seems to be doing fine.
   / Quick Hitch? #32
Seems like the only one of these that is adjustable in width, without modification, is Pat's. Am I correct?
   / Quick Hitch? #33
There is also one available at the following web site. carterandsonsllc.com. I should come clean and tell you that this is my hitch and my site. I am new to the TBN site and am just trying to let folks know that there are other choices out there.
   / Quick Hitch? #34
I have the Land Pride unit and I'm happy with it. The adjustable top hook was what sold me on the unit.
   / Quick Hitch? #35
I have the HF Quick Hitch.
Issue 1: Lower link width:
here's what I have found. "Most" of the Cat 1 implements meet, or are very very close for the 26" wide spread. BUT, some build their frame at the right dimension, and forget the Pins have shoulders on them...ooops, add another 1/2" to 3/4" inch overall. I bottle jacked mine to fit everything, then along can the KK tiller, had to bottle jack it another 1/4", no problem it works.
Issue 2: Top link height. My implements vary much more in height from C/L of lower Pins to C/L of Top Hole. It would be a pain to constantly unbolt the Upper hook for this.
Issue 3: Top Hole obstruction. The factory Hook should be able to rise up and capture the bolt or pin you have installed in the Top Hole of your implement, except, a lot of implements have flanges welded across the uprights , a few inches under the Top Pin Hole. ooops. That blocks the Hook.
Newer implements, I notice, seem to be using a different design to accomodate this issue. I used a fairly complicate assembly that still utilized the 1/2" height adjustment holes of the Quick Hitch. I will say I like the flat-stock approach that LimeCuda used, much easier and quite effective.
I am king of over-complication.
Issue 4: Just happened with the KK Tiller. The distance between the Lower Pins and Frame of the tiller would not accomodate those big hunks of steel that are the Lower hooks of the Quick Hitch. Solution: I had to cut 3/8" of an inch off of the back side of the hook. Not enough to ruin it's strength, but, look at the mods that had to be done so far?
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
PENDING SELLER CONFIRMATIONS (A56138)
PENDING SELLER...
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
2012 Club Car Precedent Electric Golf Cart (A53424)
2012 Club Car...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
