Quick Hitches Quick Hitch?
   / Quick Hitch? #1
tinman955
Pennsylvania
2011 Bobcat CT450 Cab Hoe
How many of you use a "Quick Hitch" of some sort for their 3 Point attachments? If so what brand.
   / Quick Hitch? #2
I use JD's I-Match. If you search you will find THOUSANDS of post's about quick-hitches, it can be a hotly debated topic!
   / Quick Hitch?
Thanks for the reply, I suppose your right I usually do a search first, dont know why I didnt :D . I will do one and check other posts.
Thanks again
   / Quick Hitch? #5
I'll admit I was one of them "real men don't need QH's" . Well, you know the rest of the story. I got mine from Harbor Freight. The implements are all gonna have to get the top hook connection height adjusted by relocating the bolt hole, but totally worth the effort. Now, I'm into energy conservation, Mine! There's one places it just won't work without some heavier modifications is with my JD 415-16 two bottom plow. The top link connection looks offset to one side. I just used the "other" tractor that doesn't have the QH. Also looks like connecting the PTO shaft is a bit more work when attaching the tiller or mower, 'cause I have reach under or around the "U-Frame" of the QH. I'm in the process of building a house so being able to just snap on to the implement and go is a great convience. bjr
   / Quick Hitch? #6
I too bought the JD i-match. I just plain got tired of wrestling my 600 pound chipper onto the back of my tractor. Now i just back up to it (or any other implement), raise the i-match, turn around in my seat to lock it in, and drive away. Only reason to get off the seat is to hook up the pto shaft. I can see where a hydraulic top link will be handy with any quick hitch. I have had to slightly modify some of the implements to work with the i-match, as the hole for the top link doesn't always line up. I always make them "backward compatible", so that if i needed to, the implement can always be used with a standard 3 pt . That way if if i need to loan something to my BIL, or sell an implement, its not a problem.
P.S. I 've seen where JD is coming out with an i-match that also hooks into the pto without getting off the tractor. Could that actually work????
   / Quick Hitch? #7
And I use 2 of the Harbor Freight hitches
great product for the money
   / Quick Hitch?
They look like a simple design, is one really better than another? I see them from $79-$400 bucks????
   / Quick Hitch? #9
Though i spent real money on my i-match, i'd steer you to the HF hitch for about seventy dollars. It will do all my i-match will, for about a third of the money. Do a search here for them, and read pages and pages of posts by happy HF hitch owners. I believe the problems with the early ones have been ironed out long ago
   / Quick Hitch? #10
Harbor Freight can't be beat! I did have to set up a couple of my attachments to the proper width but it's all good now! Back up lift and throw the handles down all without getting off the tractor!
2002 Semi Deck Over Trailer (A50514)
2002 Semi Deck...
2004 CATERPILLAR D3G XL CRAWLER DOZER (A51242)
2004 CATERPILLAR...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
2022 CATERPILLAR 246D3 WHEELED SKID STEER (A51242)
2022 CATERPILLAR...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
