Quick Hitch vs LX6
/ Quick Hitch vs LX6 #1
chipsdad
i have a cat 2 quick hitch and an LX6 cutter. i have found that the top linkage on the cutter will not stay in position to allow for a "quick hitch". i have to "job" a stick or something to hold the cutter linkage in place to allow for the quick hitch to hook up. is any one else having this problem. it seems there should be someway to modify the cutter so the linkage will stay in position.
/ Quick Hitch vs LX6 #2
Do you mean the upper (semi floating) linkage pin floats upward as the cutter undulates with the ground? Sorry not to have an answer but that is an interesting question as I'm looking at quick hitches. I'm all ears. How DOES the top hook retain implements when there is upward pressure on a floating link?
/ Quick Hitch vs LX6 #3
If I understand the question correctly -- the short answer is -- shorten the adjustment on the top link.
Tightening the top link should draw the clasp/hook on the I-Match hitch upward and close any gap between it and the roller pin on the LX-6.
AKfish
/ Quick Hitch vs LX6 #4
My experience with the I-match has been positive; I'm glad I have one and wouldn't go back to wrestling again with the 3pt arms unless forced into it.
But, there are inherent quirks to using any equipment and one issue with the quick hitch -- (and one additional reason why the folk's that have them want a hydraulic top-link..) is generally having to tweak the top-link hookup when attaching implements.
Often, you'll find that the top-link will need to be lowered (extended) and once the implement is mounted; you will need to shorten it to secure the attachment.
A minor consideration -- and much better than dragging out the crowbar and the scrap 2x4's.
AKfish
/ Quick Hitch vs LX6 #5
the problem is when hooking up the top hook of the quick hitch to the cutter. the cutter top hook point "flops" out of the way to a point where the quick hitch hook cannot hook it. if i could tighten the bolts on the cutter this would hold the cutter hook point in place but the bolts on the cutter linkage have bushings in them to keep them from tightening and this keeps the cutter linkage. i may can "engineer" some bunge cords to hold the cutter in place. i know this is hard to visualize but trust me something aint right.
i can tell you this ,,, if i had tried to hook up a cutter with the quick hitch before i bought the quick hitch ,,, i would have never bought it! it works fine for disk and box blade (non PTO stuff).... but from my experience it takes longer to hook up a cutter with quick hitch than with out.
thanks,,, someone has to of had this same problem....
gg
/ Quick Hitch vs LX6 #6
It don't sound quite right.. So, the top link attachment on the cutter will bend or flop/move?
And the flat steel mounting brackets to the top link on the cutter are tight?
How could the top link move if the mounting brackets are tight and secure on the deck of the cutter?
/ Quick Hitch vs LX6 #7
I found this post by N80 that has a good picture of how the LX6 top link is designed.
Note the pivot slot marked by "B".
Maybe this can help to see how the top link moves.
/ Quick Hitch vs LX6 #8
NoMO, Thanks. That definitely cleared things up! From the photo, it looks like the top-link attachment point could move, within the slot, something on the order of 1.5"-2", likely.
I still maintain that if you extended the top-link adjustment arm from the tractor 2"+ that the top hook on the I-Match would slip under and hook the top-link roller pin on the LX.
Of course, that means you have to get off the tractor and adjust the top-link and get back on the tractor and engage the 3pt. If it's adjusted right and the hitch engages the cutter; then you have to get back off the tractor and snug up the top link. So, the concept of having a "quick-hitch" is sorta lost in the final translation.
That said, IMO, having the I-Match is a much better system for using various attachments than the "wrestle with a crowbar" system.
AKfish
/ Quick Hitch vs LX6 #9
Chip,
I thought that was par for the course. The floating toplink on my rotary cutter, pretty much flops out of the way every time I try to hook it up. Basically, I've either got to get it right the first time or get off the tractor and "jab" the floating link into the quick hitch hook. Otherwise I'll raise and lower the 3pt 20 times before I finally get it lined up.
Tightening the floating link is an option, but I'd imagine that it's just the nature of the connection.
MX,
"How DOES the top hook retain implements when there is upward pressure on a floating link?"
Having the bottom hooks locked should take care of any upward pressure.
Joe
/ Quick Hitch vs LX6 #10
By the way....itsmegg.... and chipsdad are both me i am double regestered and sometimes i forget who i am......but that's a whole nuther problem.
JCB... sounds like you have a similar problem but my cutter top link wont even stay in place long enough for me to try one time. yes the bolts are tight but it has spacers in there so the linkage will "float". i can see it needs to float some but i need somehow to tighten up the floating where it will stay in place to allow for hook up.
/ Quick Hitch vs LX6 #11
JCB said:
MX,
Joe
Thanks Joe.
/ Quick Hitch vs LX6 #12
i created the attached picture to better illustrate my problem. in doing so i realized two things... ONE.. I have an MX-6 and not an LX-6, and TWO i think i found a fix to my problem as shown in the picture. I dont think there is a reason for the whole "A-frame" to float. I think if just the two arms going back are able to float I will be OK. If i tighten up the "A frame" i think it will stay in place to allow for hook up.
do you all agree.
THANKS A BUNCH!!!!!!!!!!!!!!!
/ Quick Hitch vs LX6 #13
do you all agree.
Hi Chipsdad/Itsmegg:
I have a MX5 and a JD quick hitch and I have the same problem. I think that your idea of putting a handle on the mower linkage should work. I reach back and yank on the linkage to move it forward. That works most of the time but it is hard to hold the linkage and backup at the same time.
Most people want the mower linkage to flex more not less. The more the linkage can flex the better the mower will follow the ground. (Ideally you want the tail wheel to stay on the ground the whole time you mow.) I have found that the quick hitch gets in the way and the linkage cannot flex as far as it should. So don't tighten up the linkage to eliminate flex. I think that it would be OK to tighten to the point that there is resistance and the linkage will stay where you put it but make sure that it can still flex.
Good Luck, Marshall
/ Quick Hitch vs LX6 #14
I used my I-Match with the neighbor's LX-4 last year (he actually kept my hitch for a couple months) and it wasn't nearly as big a problem as with the larger mower's -- apparently.
But one last question; if you back up to the cutter and latch the lower arms -- then, without raising the 3pt, extend the top-link and back up once again to the cutter (cutter is still laying on the ground) -- you can't push the top hook under the pin?
Sounds like you have to pull the top link brace towards the rear of the tractor before you can back underneath the link and finish hooking the quick hitch.
Still hard to visualize; if you leave the cutter on the ground -- how the brace/top link will flex rearward?
Maybe the braces should be longer, overall, to account for the rear tilting and possibly to increase some of the up and down movement of the deck while mowing...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
LEEBOY CHALLENGER 7 SWEEPER (A64279)
LEEBOY CHALLENGER...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
