Quick hitch top hook clearance issues
   / Quick hitch top hook clearance issues #11
Oh yea that is it! How did you fine that looked for quite a while.
I used Google image search, for quick and hook, restricted to this site.
Bruce
   / Quick hitch top hook clearance issues #12
Bruce
Well your computer skills are way above mine! I had you right till the restricted to this site.:confused::confused3:
   / Quick hitch top hook clearance issues #13
The search window looked like this but with www on the front of the site url. One of the images led me to that thread.
site:ww.tractorbynet.com quick hook
Bruce
   / Quick hitch top hook clearance issues #14
gundoctor- I am not trying to start an arguement here but you are not having the problem that nearly all with QH's are having because you are not reallt using your's as a QH because of that top link adapter you are using. Your qh appears to be about the same design that has the clearence problem?
Oldstuff
   / Quick hitch top hook clearance issues #15
Oldstuff,
If you look closely at Dave's picture you will see he has about three times the amount of clearance compared to the OP's hitch. I just measured my IMatch and it has about 1 1/8 " space between the frame and the hook wall
   / Quick hitch top hook clearance issues #16
Well if you had gotten a Land Pride QH it would work just fine. You now know why these off brand sell for less!!! The best is none to good.
David Pidgeon
New Haven, Vermont
Hi,
I have to say that your post is pretty much lacking in any helpfulness, (and in MY opinion, at least snotty and trollish) post to a new member who isaskingfor honest help.
Particularly when your picture shows that you can't use your toplink hook either!
Hi Fallon,
Take a close look at Dr, Dave's picture, it may help you too. It just requires a long top link pin, 2 appropriately drilled and shaped metal plates, (which couldeven have several sets of holes to match your needs, and the ability to sandwich your implement's top link with the plates. If I hadn't workd out my issues otherwise, I'd had done the same because no welding is required.
Thomas
   / Quick hitch top hook clearance issues #17
Thomas,
The steel plates in Dave's picture are to provide float for a brush mower. That is a separate issue from the hook which is clearly visible for most attachments. Some brush mowers have the flex built in so it could attach using the hook my prior Deere MX6 had the flex built in but my older Bush Hog was solid and I used a chain for the top link.
   / Quick hitch top hook clearance issues #18
These are the plates I made to fit out-of-spec implements after I riveted my hook in place so it would go deeper. I didn't notice one was reversed for the photo.
Bruce
   / Quick hitch top hook clearance issues #19
bcp,
I would have added another set of ears below the originals at 15 inches and called it good.
   / Quick hitch top hook clearance issues #20
bcp,
I would have, too, if my welder was wired. :(
Anyway, I had the strap, drill press, and bit, and thought I would try this idea.
Bruce
2 pt IH Sickle Bar Mower (A50515)
2 pt IH Sickle Bar...
Parker 250 bu Gravity Wagon / Seed Tender (A50515)
Parker 250 bu...
Polaris Ranger 1000 4x4 Utility Cart (A51694)
Polaris Ranger...
2019 CATERPILLAR D6 CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2013 Ford F-550...
