Quick Hitch Removal
/ Quick Hitch Removal #1
man00
eastern ok
kubota
Will removing the QH mess up the PTO shaft alignment?
/ Quick Hitch Removal #2
It'll reduce the distance from the tractor to the implement by about 4". Make sure your PTO shafts don't bottom out.
/ Quick Hitch Removal #3
The risk with removing a QH is the PTO shaft being too long and damaging the tractor’s PTO internals and housing/ bearing. In effect you have shorted the distance between the tractor and gear box on the implement by roughly 4 inches.
Do not connect the PTO shaft, but check your length at lots of points along the travel of the lift/lower range of the 3PH. If it needs to be shorten, there are guides on here of how to do so if you need that help.
2019 Ford Transit Connect Passenger Van (A66736)
2019 Ford Transit...
CAT 963C Cab (A68134)
HYUNDAI HL955 WHEEL LOADER (A65056)
HYUNDAI HL955...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
