Quick hitch for a 40hp tractor
/ Quick hitch for a 40hp tractor #21
I just picked up a set of CAT 2 Pats the other day for a C note and mounted them on my M.
So now along with the lower extendable arms, hooking up my winch and box blade is a snap.
/ Quick hitch for a 40hp tractor #22
I like quick hitches as I can back up to implements and hook up only getting out to attach the PTO shaft. A hydraulic toplink makes life much easier. I have an Agsmart cat 1 quick hitch on my 45hp tractor. It does not work on every implement such as the moldboard plow and my box blade (Massey MF18 made by Gill its a weird design where the ripper pivots around the lift arms) or my cat 2 back blade. However it is sure nice the rest of the time. The quick hitch is good and has not had any damage from the tractor. All of my implements are old, pretty sure the Alamo flail was made in the early 90's so it would be the newest.
My method is to back into the implement so its straight on the tractor then lift the 3pt and if your hook is set right you don't have to get out. To unhook I lower the implement to the ground then get off and flick the levers up so the implement lowers to the ground then flip the levers back and adjust the hook for the next implement. I can then go to the next non pto implement back up and hook without ever leaving the tractor, only leave to unhook. I have a cab so its a pain to get in the cab to raise and lower the arms.
Quick hitches are the way to go and I have used them from cat 1 to cat 3. If your good at modifying stuff or you have newer implements then go with a quick hitch. If your not up for the weld and modify pats is the way to go in my opinion.
/ Quick hitch for a 40hp tractor #23
My "Euro" hooks work the same way only I can adjust them for any width implement. They are much better then a quick hitch.
You can have your quick hitch, I have no desire or need for it. And, I don't have a big piece of steel in the way when I go to hook up the pto.
2006 CATERPILLAR D5G XL CRAWLER DOZER (A60429)
2006 CATERPILLAR...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
