Quick Fix for a Broken Hydraulic Hose?
   / Quick Fix for a Broken Hydraulic Hose? #1
jpsheb
1959 Ford 641, 2011 Kubota M6040
Hey folks - I hope everyone is having a relaxing Memorial Day weekend!
I picked up a Ford 7710 a few weeks ago that over all seems to be in solid running condition. It does however have the signs of age and needed maintenance. One of these is the hoses.
Once I'm done with a final push the next few weeks skidding tree stems I plan to go through all the hoses, fittings, and get her on a good maintenance cycle. But for now, I'm trying to keep moving!
Today a rear remote hydraulic hose burst when lifting the 3PH. As soon as I let it down, even if just a little bit, it stopped. I'm fairly inexperience with hydraulics so I wanted to ask you all for advice on the quickest way to keep the tractor moving for now.
I included a couple pictures, with the burst location circled in yellow. It feeds a remote fitting that is for currently unused, so for now I just want to keep hydraulic fluid from spewing out when the 3ph is lifted. Would removing the burst hose for now and capping the end of the metal hydraulic line where the hose was threaded on (circled in green in the 2nd pic)? Would this cause any issues for now? What would happen if I took the end of the other line from the remote (circled in orange) and joined it directly the end of the metal line, bypassing the remote hookup? Would this prevent the 3ph from lifting?
These may seem like some dumb questions - but I appreciate any help or suggestions I can get!
   / Quick Fix for a Broken Hydraulic Hose? #2
If you can take the whole hose off easily, just take it to a tractor or truck shop and have them make you a new one. Probably take them 15 minutes to do. Then it's done and you won't have to worry about ancillary issues.
   / Quick Fix for a Broken Hydraulic Hose? #3
Y'all don't understand, he has to keep moving....
   / Quick Fix for a Broken Hydraulic Hose? #4
If that remote is not used you should be able to just cap the steel line.
What I am not sure of is why that line would be pressurized while using 3 point. Do those lines connect to a directional control valve?
   / Quick Fix for a Broken Hydraulic Hose? #5
To answer your question...the best way to be able to make a quick field repair on a hose is to be prepared (in the future)...
Have on hand a plethora of different size male and female fittings and adapters etc...and several generic hoses of varying lengths and sizes...
hoses with simple male NPT are not expensive and using a variety of NPSM (female swivel) fittings...and a hose with male ends can usually be made to improvise for just about any typical tractor hose problem..
The NPSM fittings mentioned are National Pipe Straight Mechanical (swivel) they are a mechanical type fitting that requires NO sealant or lubricant etc...they can be used multiple times without issue...
One caveat of storing hoses and fittings...if you live in an area where there are "mud dobber" wasps etc...keep the hoses and fittings in a sealed bag or container...I use the big plastic tackle boxes from Wal-Mart for my fittings etc...
   / Quick Fix for a Broken Hydraulic Hose? #6
My local Tractor Supply Company has 3/8" and 1/2" hydraulic hoses in various lengths in stock with NPT male fittings.
   / Quick Fix for a Broken Hydraulic Hose? #7
i understood.....it's just that sometimes the best move is to take the time to get it fixed properly. Plus....I could not answer his questions regarding rerouting other hoses, etc. for the quick fix.
   / Quick Fix for a Broken Hydraulic Hose? #8
This is a big question and may very well indicate other problems if it is actually a standard rear remote.
gg
   / Quick Fix for a Broken Hydraulic Hose? #9
Only real (quick) fix is to replace line.... Once its damaged and leaking it needs to be replaced....IT will be faster to replace line than to have to let tractor sit in shop or have to stop and try mickey mouse fixes several times that really don't work.... Sitting and waiting for opinions or solution does not get tractor moving...
IT equates to a tire damaged beyond repair.... What do you do, you replace it...
   / Quick Fix for a Broken Hydraulic Hose? #10
Them quick fixes always work.
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
2018 KENWORTH T800 DAYCAB (A55745)
2018 KENWORTH T800...
WHIRLPOOL DRYER (A54757)
WHIRLPOOL DRYER...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
black Max power washer (A53421)
black Max power...
2019 Chevrolet Silverado 4x4 Service Truck (A55852)
2019 Chevrolet...
