Quick Fix for a Broken Hydraulic Hose?
   / Quick Fix for a Broken Hydraulic Hose? #21
Thanks for all the replies – The main reason I asked was I was hoping there was some quick fix I could do, since I’m using it at some forest land we have 2hrs from home (where the hydro supply shop and tractor supply are close). Up here for the weekend, and wasn’t expecting anything around here to be open, and did need to keep working..
After sleeping on it and then reading y'alls advice I think I’ll just pull the hose (and a few others) and get new ones & spares. I checked my limited parts in my truck and I don’t have the plugs I thought I had. While I could loop the in/out lines together (bypassing the remote ports), it seems like an odd setup so I didn’t really want to go hacking something I didn’t really understand. Plus, I have a skidsteer and chainsaws with me and there is a lot I can do with that today and tomorrow. All things considered, though I need to keep working, skidding the stems can wait a few days.
Some of you raised some real good questions – like why it is pressurized with the 3PH operation and if it is a standard rear remote. I’ll tell you what I know and maybe we can figure it out.
More detail about when it burst:
- Once it burst and sprayed, the 3PH with about 2000-lb on quickly lowered – it didn’t crash down, but it did go down quickly. I quickly (~1sec) pushed the 3PH lever to the down position and the spray stopped immediately. Being in the cab I had no idea where the fountain of oil came from.
- After shutting off the tractor and finding the (likely) source I restarted the tractor and from beside the tractor very gently moved the 3PH control to up until it tried to raise (and fluid spurted out). By “tried to raise” I mean it just budged. But I didn’t want to apply more pressure since the little flow I was giving it was already running out that burst remote hose.
Q: Why is it pressurized with the 3PH?
Great question. I don’t know. Both lines come out on the front part of the cast iron housing of main gear case (correct me if that’s not what it’s called) that the 3PH linkages come out of. There is no separate directional control for these lines that I can see. I’m guessing the prior owner had put on there to run a 3PH implement. But that’s just guessing – why set up something that only kicked on when upward pressure was on the 3PH? I’ll try to get a pic of the source of the lines shortly.
Q: Is it a standard rear remote?
  • Also a good question, but I don’t know this either. It doesn’t look like it to me. The dealer (T&J Equipment in South Hill) didn’t know what it was for when I was getting details before buying. It does look broken, so unless I have a good use for it, I’ll consider just capping it off at the source. From what I can tell, the flow is only one way – pressurizing only when the 3ph lifts. Any theories?
  • There is another set of remote ports you can see on the right upper side of the 3PH. The two lines coming out supply the FEL control valve. Not sure what the two empty ports are for, but I may use them for a grapple on the FEL. I think a more protected routing of the FEL lines is in order, especially since this tractor is for woods work.
To answer both questions about why it is pressurized with the 3PT and is it a standard remote. It is part of the Load Monitor draft control system. The way the system works is that you have a plow hooked semi-mounted to the 3 PT or on the drawbar and the plow has a special Load Monitor hydraulic cylinder on the plow lift wheel. That cylinder gets hooked into that remote. The remote then works in tandem with the 3PT to raise and lower the plow as draft on the plow increases or decreases. Load is sensed by the Load Monitor driveline sensor that measures torque or draft applied to the drive system. The original special Load Monitor hydraulic cylinder could also be adapted to work like a regular 2 way cylinder. I believe what was special about it was that is had a poppet valve on the piston, but also think that a regular 2 way cylinder could be used.
You can tell if a tractor has Load Monitor if it has that big spring on the LH lift arm.
   / Quick Fix for a Broken Hydraulic Hose? #23
To answer your question...the best way to be able to make a quick field repair on a hose is to be prepared (in the future)...
Have on hand a plethora of different size male and female fittings and adapters etc...and several generic hoses of varying lengths and sizes...
As a suggestion: If you want to keep the spares and cost to a minimum, try the following. I like to use DiscountHydraulicHose.com. Purchase a long 1/4" hydraulic hose, say 25 feet. With it, buy some "Field-Attachable (Reusable) Hose Fittings", for example standard NPT for the 1/4" hose. The fitting types do not require anything more than two wrenches to attach to hydraulic hose. Add any fittings you think you need to adapt the NPT to various sizes or types (e.g. swivels, JIC or Boss). When you have a "temporary" need, you can cut the hose with a grinder-type cutting disk to the required length, then add the Reusable fittings. Works well. Volume/speed may be less than the 3/8" or 1/2" hose that it is replacing, but at least it works until you can get a full replacement. The Reusable fittings are just that - reusable.
   / Quick Fix for a Broken Hydraulic Hose? #24
I'm curios why it burst when it was not being used? That says it is being presurized and you need to simply cap it off or replace it.
   / Quick Fix for a Broken Hydraulic Hose? #25
For the explanation, jump up 3 posts prior to yours (5/30/22 11:48 a.m.) by TractorTech.
John Deere 5090GN (A60462)
John Deere 5090GN...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
