Quick fist clamps or similar tool connector?
   / Quick fist clamps or similar tool connector? #1
Dadnatron
Versailles, KY
JD 5100e with FEL
Does anyone have information or recommendations on a way to attach a shovel to a quick hitch?
I am always needing a shovel it seems, and I have no good place to carry one on my tractor. But I recognized I could mount one across my QH pretty easily.
I have been looking for something secure and easy to use, and found these Quick Fist connectors that look like they'd do the trick pretty well. But I see a few versions of them, and having no personal experience don't know whether one type would fit my needs better than another. I don't know if the only variations are size or other attributes.
   / Quick fist clamps or similar tool connector? #2
Stick it through the tube on the loader behind your bucket. At least my Kubota L3200 & L4060 have had a hollow brace tube there. Have some snow stakes in there on the L4060 now. They occasionally slide out & the shovel in the L3200 did too. Never got around to putting a rope or magnet or something on there to hold stuff in place.
I have a pair of Quick Fists holding a short shovel in the back of my truck for the past 7ish years. Still working well there, although I dont remember which models they are. I'm guessing they are origionals.
   / Quick fist clamps or similar tool connector? #3
I have one on the Ranger, seems to be good quality rubber. Works well and has been on there for over two years.
   / Quick fist clamps or similar tool connector? #4
We use them a lot on our fire trucks to hold everything from nozzles to shovels to heavy bars they are plenty rugged and work well.
   / Quick fist clamps or similar tool connector? #5
Xfaxman thanks for your post
Modified my wood splitter with quick fist I had on shelf
Solved a problem with pickaroon
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2014 Ford Fusion SE Sedan (A55853)
2014 Ford Fusion...
Eagle Weathervane (A55853)
Eagle Weathervane...
