quick disconnect tast
/ quick disconnect tast #1
jinmared
Goldendale,Wa
Jinma 354 fwd
How can I test my quick disconnects to make sure that they are working correctly?
/ quick disconnect tast #2
By observing the attachment is working correctly. A cyl is extending and retracting, a hyd motor is turning, etc. The QD's could be partially open, and things will not work as expected. You can test for correct pressure by plugging a hyd test gage in the QD's
/ quick disconnect tast #3
What problem are you having???? Quick disconnects are either open or closed, if they are connected and snap into place then they are working properly, if they will not snap together then they are not working properly (could be residual pressure preventing them from connecting), if they are disconnected and leaking then you have a problem and they need to be replaced. if they are connected and leaking then they need to be replaced. There is no such thing as a connect half working unless it is plugged with some crap and it this is true them there is some big problems in the hydraulic system. By plugging in a pressure gauge to see if the qd's are working , this will tell you nothing, the little space between the qd and the gauge will fill a milli second no matter if it's good or almost totally pluged, you will have to install a flow meter to see if the qd is flowing properly. Jim
2019 JOHN DEERE 331G SKID STEER (A65053)
2019 JOHN DEERE...
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
46192SFL (A64557)
46192SFL (A64557)
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
2007 FREIGHTLINER COLUMBIA TANDEM AXLE 6 X 4 TRUCK TRACTOR (A67147)
2007 FREIGHTLINER...
