Quick disconnect quality difference
/ Quick disconnect quality difference #21
Thanks Andy! About 26GPM @ 60PSI for the 1/2" is darn good. Do you have the flow numbers on the Pioneer poppet style typically used on tractors? Im going to have to find out where my pressure losses are. I looked again and there are no QDs that fluid has to pass thru in the circuit from the pump outlet back to the reservoir, yet at 17GPM that line runs a pressure of 700PSI at the pump outlet - a total waste of the mechanical power needed to produce 7hyd HP. Im think the loss Im seeing is due to one or all of the valves the flow transits [loader, 3PH, factory remotes] being restrictive. The hyd tubing is large. I cant believe that it, combined with about 10 feet of 1/2 hose, could account for near that backpressure. Seeing about 500psi/5 mech HP being wasted even at rated PTO rpm is bugging me. Fortunately the tractor does fine at 15-1700 rpm where backpressure is only about 200 and at only about 10gpm.
larry
/ Quick disconnect quality difference #22
Larry,
The pioneer style poppet #'s should be page 40.
700 psi no load does seem high.
2014 JCB 930 (A53317)
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2008 Ford Ranger Ext. Cab Pickup Truck (A59230)
2008 Ford Ranger...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
