Quick Coupler Size on Deere 4300 Loader
/ Quick Coupler Size on Deere 4300 Loader #1
tobinator1959
My tractor is 200 miles away, so I can't just look at it /forums/images/graemlins/frown.gif. Does anyone know what size the quick couplers are, where the loader connects to a Deere 4300. I'm guessing 1/2", but they may be 3/8". /forums/images/graemlins/confused.gif
/ Quick Coupler Size on Deere 4300 Loader #3
Check out JD Parts by scrolling down the page and click the yellow "John Deere Parts Catalog" link... then enter your loader model # to search. Then you can look through the Sectional Index of images to find the corresponding part #... the size is usually listed in the far right column.
/ Quick Coupler Size on Deere 4300 Loader #4
Thanks, but I already tried that and all it gave me was the part number.
/ Quick Coupler Size on Deere 4300 Loader #9
I'm betting on 3/8 too.
If you feed that part number back into the part number lookup box on the home page of jdparts, it should come up with a more detailed description. If you have registered with JD and specified a local dealer, it often tells you whether it is in stock and the price.
Tom.
/ Quick Coupler Size on Deere 4300 Loader #10
Tom.
/ Quick Coupler Size on Deere 4300 Loader #11
I think the fitting is 3/8 nominal size. But it is the same one as on my 4600. ( PN AM105466) It is a Parker series 60 hydraulic coupler. It is set up with staight thread "O" ring style, not pipe thread. I think it is t-8 thread, which is a nominal 1/2"ID ( the number being the nominal 1/16 ths ). Even when you know it is better to have the piece in front of you. These are NOT compatable with the 1/2" pioneer fitting that are used on the power beyond. Each manufacturer of the fittings has thier own "style" . Only a few work with each other. Why different vendors for different parts of the hyraulics I will never know ( Low bid of the day ??). I needed to find a parker store to get the fittings, the dealer was no help in setting up tractor implement hydralics- must be hard to find good help- or too expensive. They just wanted part #s. If they could help I would have bought them with the JD markup! So I figured out what I needed past the deere quick couplings. I can get the parker part # off the male fitting I bought for various uses that hook into the front and the rear remotes. I stayed with the deere fittings, because 1)I want it easy to service, and 2) parker is a better brand than pioneer ( IMHO ). Go to the parker website, there may be a parker store near you. There are so many products that it is hard to find the right website. I just looked up the catalog lets see if I can LINK to parker The fittings I got are H3-63-T8 this is the 3/4" OD straight thread O ring style to the hose or hard pipe. The other style available is the 3/8" NPT. Looking at the catalog will keep yo busy, I hope it helped.
/ Quick Coupler Size on Deere 4300 Loader #12
1980 Fontaine Flatbed Trailer (A65563)
1980 Fontaine...
40ft Shipping Container (A65583)
40ft Shipping...
ALUMINUM TOOLBOX (A64277)
ALUMINUM TOOLBOX...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2005 Mack Vision CNX613 (refurbished and retrofitted as novelty pick-up)  (A62613)
2005 Mack Vision...
2008 HEARTLAND RV CYCLONE 40 FOOT TOY HAULER (A59914)
2008 HEARTLAND RV...
