quick coupler flow question
/ quick coupler flow question #1
backintheday
Wyoming
Branson 3510H
My snow blower can operate between 11 and 25 GPM and uses 1/2" QD which from what I've seen max out at 12GPM. It it worth it to install 3/4" QD on 1/2" hose to allow more flow or is the 1/2 hose restricting the flow as well. I'm in the process of gathering parts for a PTO power pack and I want to build it right the first time, any advice is appreciated, thanks.
/ quick coupler flow question #2
A good practice is to install one size higher QD over the hose size.
/ quick coupler flow question #3
The other thing to make sure is that the QD you get are high flow rated. Different style QD's have different flow ratings. Flat face are usually higher rated than the pin or ball type.
/ quick coupler flow question #4
These 5/8" Flushface Couplers are rated for up to 27 GPM
Set of 5/8" ISO 16028 Couplers with 3/4" NPTF Female
Of course, changing the couplers to accommodate your snowplow may complicate things for the other attachments you use. You may need to change the couplers on all of your other attachments as well. Flushface couplers cost a good deal more than the standard agricultural couplers, so that is a consideration as well.
/ quick coupler flow question #5
What chart did you use to obtain that GPM
Those figures are hard to believe.
What is your reference?
Hose Size Selection Nomograph - RYCO
/ quick coupler flow question #6
I internally blew apart a typically Ag type coupler many years ago. As I dug into the vendor's catalog (maybe Parker?) I was surprised by the number of difference, but compatible, couplings they made. All varied by quality, cost and flow. Also, it's been many years since I looked into this, but I don't remember there being any standard associated with the quoted flow value so the vendor could pick any pressure drop they wanted.
As far as the original question goes, any reduction in pressure drop is a good thing within reason. You will reduce the heat generated and fuel burned. The actual savings will vary considerably depending on the conditions.
ISZ
/ quick coupler flow question #7
The Parker 3800 catalog has the pressure drop curves. 25gpm was way off the chart for 1/2" couplings, but if one extends the curves you are looking at 50-100psi pressure drop with warm oil. (assuming it doesn't cavitate, which is a definite possibility.) A 3/4" coupling, depending on the design, is 7-20psi pressure drop.
worst case: 25gpm x 100psi = 1.5hp
best case: 25gpm x 10psi = 0.15hp
assume 0.5 gallons/hr savings, or ~$2/hr
ISZ
/ quick coupler flow question #8
I can't figure this out. I agree that 1/2" couplers are rated for 12gpm, but my skid steer, from the factory, pushes 36gpm through them. My new pump has been flow tested at 46gpm. Same couplers are on the high flow side as the standard flow. I have a hunch that the rated gpm is base upon pressure loss and when dealing with 3,000 psi you can afford to lose a few psi at full flow. Generally when the pressure starts to rise the flow drops off anyways.
/ quick coupler flow question #9
/ quick coupler flow question #10
I got those numbers from our own catalog, which appears to be incorrect now. I checked the 2014 Dixon Quick Coupler Catalog, and they show 5/8" ISO 16028 couplers at 21 GPM maximum flow rate.
/ quick coupler flow question #11
Experience is the best teacher when it comes to quick couplers. There is so many different "standards" that the MFG's use it's pathetic. For good flow per hose size I stick with the ISO B quick couplers [poppet style] and for my high pressure high flow units, I use Stucchi VEP flat face series. To give a example a VEP 1/2" would give you a total pressure loss of 90psi for a circuit at 25gpm. 45psi per coupler. I would not use 1/2" hose for 25gpm. 3/4" pressure lines are a better choice. Esp in the winter. CJ
/ quick coupler flow question #12
Cord, understand that you can always push more through than rated. In simple terms the quick couplers are just a restriction, so it all comes down to how much pressure drop you can live with. And like several of us have noted, there is a wide range for a given size coupler - even within the same companies products. It is all a compromise between cost, durability, pressure drop, ease of coupling and seal integrity. ISZ
/ quick coupler flow question #13
And the -12 hose size results in 44 feet per second velocity at 27 gpm which is triple the recommended maximum.
/ quick coupler flow question #14
???? are you sure ? I am showing about 26. Well within spec for pressure lines. CJ
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
2023...
10ft S/A Utility Trailer (A66738)
10ft S/A Utility...
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
