Quick connect problem with FEL
/ Quick connect problem with FEL #1
Citrus breeze
Dunnellon, FL
Kubota 2800
When I took of my brush rake from my kubota 2800, I noticed that the forward hydraulics extend differently. Now I can,t mount my FEL! The quick connect couplers don't line up.
How can I correct this problem?
/ Quick connect problem with FEL #2
Those cylinders are teed together so pushing on (retracting) the one that is extended more should extend the other. You might need a bar or something to get enough leverage to move it, or use an object to push it against. Your bucket may work to equalize it, it does on my Westendorf loader.
Kim
/ Quick connect problem with FEL #4
I'm a little confused as to what you are saying: "...forward hydraulics extend differently..." Do you mean the FEL settled and is leaning? If it's leaning to the either side, you'll have to jack it up somehow so you can drive into the FEL.
Once close, you hook up the hydraulics and use them to make adjustments to mount it. A photo of the problem would be great... :thumbsup:
I'm new to this forum as well as new to FEL(front end loaders). On the Kubota L2800, there are two quick connect pads that catch the device you want to hook up. I'm talking about the hydraulics pistons that control the "tilt" of those pads. One side extends out further than the other which makes one quick connect pad rest higher and further back than the other.
Does that help? If not, I could post a picture when I take the "rake" off soon.
Thanks for the reply!:)
2025 Swict 84in. Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
Mounting Plate Skid Steer Attachment (A61572)
Mounting Plate...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
