"Quick Bite"
/ "Quick Bite" #11
/ "Quick Bite" #12
I just back up until there is a crash, then I know to pull forward three inches. Even works in the dark.:thumbsup:
/ "Quick Bite" #14
JJ, I have seen those also, and wondered about them. I imagine it would work good with the mirror. Bob Six Hoe would enjoy one of those.
/ "Quick Bite" #16
There are alot of gadgets and gizmos out there. That quickbite thing doesn't look any better than the rest.
If you couple trailers enough you get pretty good at it without any extra gadget. I did buy some of those magnetic back up balls for my equipment trailer with ball hitch. They work great and are well worth the couple of seconds it takes to set them up. I don't need them for my pintle hook dump trailer since it's a bigger target.
JB
/ "Quick Bite" #17
you'd still have to be at the correct height and alined. It doesn't look all that bad but not worth the price IMO.
/ "Quick Bite" #18
That's the thing, I think it's worse than a regular coupler, unless you were on perfect level ground and never changed the weight/height of the truck.
With that thing you have to hit 3 dimensions. side to side, distance to and height. the height being the trickiest one. with a regular coupler it's just side to side and distance to. I wouldn't use that thing if you gave it to me.
The thing JJ links to would help some people I'm sure, they have them a HF now. Save you from hacking up the back of your truck a little, as long as you can get CLOSE to the target :)
JB
/ "Quick Bite" #19
JB4310; I believe they're trying to copy something like a big rig but the thing about a TT is that as the truck backs under it raises the trailer which inturn gives a solid hook. With this setup things would have to be right one the money, otherwise it might end up with a bad hookup or broken parts. I also think what JJ posted would be better, but hey, the world is constantly changing.
/ "Quick Bite" #20
What about this "Snap Hitch"?
More of a 5th wheel style. Looks more forgiving re: alignment. Plus it might provide some security if the pin was locked into the trailers hitch.
Does seem to add a bit of extra length between truck and trailer though.
YouTube - SNAP HITCH
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
CAT CB34 (A60462)
CAT CB34 (A60462)
2025 AGT Industrial MX-MRT14 (A60463)
2025 AGT...
Land Survey Kit (A60463)
Land Survey Kit...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
