quick attach plate
/ quick attach plate #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
i would appreciate it very much if someone would send me the measurements for the quick attach male plate for an early 90's pt-1445. i think it is 5/8 in thick. i have the steel and plasma cutter and ready to go. thanks
j.j.
/ quick attach plate #2
I might be wrong but I don't think they started using the quick attach plate on the power tracs until about 1998. The older ones used a 3 point hitch setup.
i believe that the quick attach hooks up as a three point hookup. check for me and see if yours hooks up on 16 in centers. what i plan to do, if i can get the measurements, is to cut out the plate and weld on the brackets for the three point hookup, my arms on the pt-1445 are 16 in centers.thanks
j.j.
/ quick attach plate #4
what i think you could do would be to order the plate that goes on the attachment from P.T. then manufacture your plate fit it. /forums/images/graemlins/smile.gifby doing this it gives you the pattern for it also.now you know everything will work together. /forums/images/graemlins/cool.gif
Would someone that knows the measurements for the Quick Attach plate for a PT-1445 please fill in the blanks
bottom length__________
straight side __________
angle cut in inches ________
top ________
thanks
j.j.
/ quick attach plate #7
See attached Pic for dimensions...
Many thanks, and what is the thickness, 1/2 or 5/8 in?
RoGator RG1300C (A63118)
RoGator RG1300C...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2019 F150 (A61306)
2019 F150 (A61306)
