Quick Attach Binding
/ Quick Attach Binding
By ramps I am referring to the ends of the pins where they are angled.
but, its possible your other attachements are a little loose too (maybe just not as bad as the 1/4" gap mine have LOL)
/ Quick Attach Binding #12
Gotcha. The only time mine ever sticks is on my bucket. My grapple or stump bucket are never an issue.
/ Quick Attach Binding #13
Just a suggestion, if the stock bucket is the only thing that sticks.. why not take a file and bevel the slot just a bit on the bucket to make it easier.. Of course keep the pins lubed, I use Fluid Film on my Kioti. When I go the Kioti, both my forks and my old Kubota bucket were a little tight, so I just filed them a bit. It just makes it easier to get started and to release.
Fluid Film is what I plan to use as soon as i get some!
Mine is only a problem getting off. And its only the bucket because of the 1/4" gap on the other implements that I have yet to fix... (I suppose now that I have a welder.... I should fix them)
I can try putting a little chamfer on the bucket to see if it helps, but I suspect lube will be the key!
/ Quick Attach Binding #15
I have problems with my left side pin getting jammed both attaching and detaching. It happens on almost every attachment. I have noticed the handles going past vertical, so I will check that along with taking closer note of the attachments that it happens more to. Thanks for the help! :)
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
2011 JOHN DEERE 544K WHEEL LOADER (A62129)
2011 JOHN DEERE...
John Deere 50 (A60462)
2002 POLAR TANK (A60736)
2002 POLAR TANK...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
