Backhoe Questions Re ROPs Options and Backhoe on L '30s
   / Questions Re ROPs Options and Backhoe on L '30s #21
Re: Questions Re ROPs Options and Backhoe on L \'30s
Yes, the BRadco mount hangs the hoe further astern than on the Grand L10 series. I suspect it's to provide clearance so it can be used on the Cab models too, but I'm not sure. From eyeballing the mount, I think it will fit, but I don'tknow for sure.
The Woods mount is like th eBradco - hangs out further, but this has always been the case with the Woods mounts.
   / Questions Re ROPs Options and Backhoe on L '30s #22
I have the Bradco 509 on my L 3830. With 82 hrs on the tractor now (great deal with the backhoe) I can say it is exceptional. Comes off in about 2 to 3 min. my friend has the B 7500 and the Smaller bradco, his seat does have to be up to change to backhoe. It is much more convienient to transfer from your tractor to the back hoe with out having to raise one seat then lower the next. The frame is extremely solid with great ground clearence and does not interfere with the 3 pt attachments. Took off a cliff behind my barn to get my tractor behind to ditch, couldn't hardly walk behind before. Now for the first time in years my barn is dry on the inside. Not sure that I could have done it with any less bucket curl strength. I am sure the bh90 is good, but you can't go wrong with the 408 or 509 bradco.
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
AGROTK HAMMER (A58214)
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2008 IC Corporation PB105 School Bus (A55973)
2008 IC...
