Rotary Cutter questions on Woods M4 Billy Goat rotary cutter
   / questions on Woods M4 Billy Goat rotary cutter #1
BrentB
il
JD 4200
I just bought an old Woods 4 ft rotary cutter to use behind my Deere 4200 tractor. When I lifted it up off the ground the rear tire barely came off the ground...its as if the whole geometry of the 3 point locations is wrong. I'm wondering if this is a category 0 hitch arrangement. The lift arms fit the pins okay, but I had to bring them in more than usual, and the centerlink pin was too big.
I also need a new pto shaft for it...does anyone have a recommendation on where to buy a good quality one at good price? Northern Hydraulics has one for $90...how is the quality?
Thanks!
Brent
For some reason my original post doesn't show up in the new posts area, so I'm sending an update to see if that posts. I wound up buying a pto shaft from Agri Supply for $64. still trying to figure out how to go from 1" shaft up to 1-3/8" pto yoke...it seems to be a special bushing from Woods that costs over $100. It didn't look like the existing shaft had a shear pin-it was keyed direct from yoke to shaft.
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2015 International DuraStar 4300 26ft. Box Truck (A55852)
2015 International...
