MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,233
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
PineRidge said:Don't know if it's practical or not but I would like to set up a laptop computer to run a Power-point slide show in the background. The presentation would actually be displayed on a remote, wall mounted 26" flat screen monitor that will be around 37' from the laptop itself. While the presentation is running I would also like to be able to use the laptop for other applications ie. email or web site surfing. Is this possible, and would I need any special hardware or software? Will the laptop itself require any special configurations or memory requirements to work without being to slow?
Keep in mind that I have yet to purchase the laptop, monitor, or connecting cables so I would appreciate any input so that the correct equipment can be purchased the 1st time around.......
THANKS in advance!
Most decend laptops are now capable of running an external monitor at the same time as the laptop display. I do this every day at work. Just extend my desktop to cover both monitors. The mouse moves back and forth between them and you can drag any program to the other monitor or half way or whatever fits your needs. So, I would drag the Power Point presentation to the other monitor, maximize it and it will automatically fill the second monitor. I have a 50' VGA cable that works fine for this. I can plug it into the second monitor, projector or video input for our in-house cable TV distribution system and away I go. I can work on my laptop screen while the Power Point program runs on the other monitor.
The only thing you would have to worry about is the length of the cable and some signal loss. But I can tell you that I have been running several machines with remote monitors on cheap, crummy, inexpensive VGA cables with no problems whatsoever for 10 or more years. It should work fine.
