Questions on MX machines
/ Questions on MX machines #1
ChemE
Missouri
L2501-HST/4wd/Loader
Hi All,
I currently have a L2501 that I will be upgrading to a MX machine. Initially was going to get the MX4800 to stay away from a turbo. My concern was that if not used a lot a turbo would have problems like newer diesel trucks (the fuel is the lubricant), is this a problem with tractors also? I have 170 hrs on my 3 year old L2501.
Next question, is if I did go with a MX5200 or 5800 what is the largest rotary cutter I could use? Maybe a twin spindle 10 fter or larger. This would be grass hay fields as the guy who cuts my hay is not paying anything, so I may just cut it myself a couple times a year (26 acres of field).
ChemE
/ Questions on MX machines #2
Your understanding of turbo vs reliability is skewed. Forget whatever horse honkey you have heard. If anything, a turbo will be more reliable for you as the turbo eases the strain on your engine to create the same horsepower.
Rule of thumb is 5hp per foot of rotary cutter. A lot depends upon what you are cutting.
To me, in my opinion, you get the most horsepower you can afford. The MX series is a good tractor. I would not consider anything less than the MX5800.
/ Questions on MX machines #3
I suspect you may be wrong here.
A turbo essentially lets a smaller engine create the same horsepower as a larger one... but it's still the engine "creating" the horsepower; all the turbo does is push more air into the engine.
If anything, the smaller engine is going to be under more stress than a larger one at the same hp. This is the reason why medium duty trucks get "de-rated" engines compared to the higher hp light duty trucks -- bigger engine with less hp equals less stress.
Turbos engines also can have problems if they're run hot and then turned off, the oil in the turbo can "coke"; it's essential to idle a bit so that the turbo isn't super hot before shutting down... this is a failure mode which non-turbo engines don't have. It's probably less of a concern with tractors than with sports cars, though; a car may be run hard right up to a parking lot and shut off quickly (... to evade capture? i certainly don't have personal experience with this...), but a tractor that's run hard is typically run hard in a field, and typically it's working much less hard before being put away. Anyways, it's something to keep in mind with turbos, especially as tractors probably don't have temperature dependent oil pumps that will continue to circulate the oil after the key is turned off.
Regardless, in any of our hands, there should be a negligible difference in reliability as all of these engines are built well to produce their relatively pokey hp.
/ Questions on MX machines #4
I would want a cab on the tractor mowing 26 acres. Heat, humidity, sun, bees, dust and pollen too awful mowing that much area. Kubota does not offer cabs on the MX series tractors.
Operating a Rotary Cutter is one tractor application where tractor horsepower, particularly tractor PTO horsepower, should be your first consdieration.
Most mowing is done in HST/MEDIUM range.
Calculate mowing time with various width mowing implements:
Mowing Calcuator | How many acres can I mow in an hour
/ Questions on MX machines #5
Maybe a twin spindle 10 fter or larger ChemE
10' twin spindle? assume you mean the pull behind finish? certainly not 3ph.... even so, that's a lot of cutter for the MX series. high growth will bog it down & increase mowing time..... imho a 6' 3ph cutter would be my choice with that set up
(that was my previous set up w/an MX5000). imho a 3ph is more versatile than drag type cutter, but each circumstance is different.
and yes, go the largest of the MX series. many here will advise cab. my preference would be take the money you'd spend on an MX cab and go with a 60-70 hp M series open station that would give you more rotary cutter options
but that's just personal, i tolerate the elements just fine as long as the machine is properly matched to the task. after all, you don't make a living with your tractor...i just save the a/c & heater for my vehicle & home. best regards
/ Questions on MX machines #6
You don't idle them because the turbo is "super hot", it's because the turbo needs oil moving to the bearings while the turbo spins down...
Turning the engine off, stops oil pressure, then "that" oil stops going to the turbo bearings with the turbo still spinning for several minutes after the engine is off. BUT, letting the engine idle, keeps oil going to the turbo bearings and gives the turbo time to spin down...
SR
/ Questions on MX machines #7
The MX series tractors almost always get great reviews. I wouldn't be afraid of owning one.
It surprises me how many people are afraid of turbos. They are a simple device that doesn't require any maintenance and failures
in heavy equipment and farm machinery seem fairly rare.
Keep your engine oil in good condition and you would likely never see turbo issues.
Thanks Everyone! I currently use a Landpride 2660 cutter with my L2501 and have cut the fields once before, but mostly trim the field edges and have been taking back briar filled areas. I assumed since L2501 could handle the 5 ft. cutter in pretty tall stuff, that a MX5200 or 5800 could handle a 10 ft rotary cutter (yes a pull behind, but wasn't going to get a finish mower). I would prefer an open station because the rest of the 356 acres is woods and don't really want to beat up a cab with branches.
LOL, the only diesel I own is the tractor as my F350 is a gas motor. I have several friends who advised me to go gas when upgrading trucks (they all have diesels), due to not driving it much. So no, I'm not an expert, haha. My truck does pull an 11,000 pound skidloader fine, but its right at the max conventional towing load of 15k with the trailer. And true, of all 4 skidloaders I have pulled the older Case 85XT is a turbo and still kicking at around 3,000 hrs, leaks hydraulic fluid like a sieve.
I was fine with the quotes I got for the MX4800, not just need to see what the difference is to the MX5800. Thought is was an additional $1200 to $1500 to go to the MX5200.
/ Questions on MX machines #9
You want to run a 10' rotary cutter with a 45 or 50hp tractor???
Don't count on that working out too well!!
SR
/ Questions on MX machines #10
SR
agree. no brainer. esp w/dull cutters & heavy growth. can't have it all....imho many members are too ambitious w/under powered machines. now is the time when buying new to select the right machine for the task at hand. if you want an MX, get the 5800 w/a 6' heavy duty rotary 3ph
or step up to the M series that will expand rotary options. best regards
Hey SR, that's why I was asking! Thanks for the feedback.
If I stick with what is suggested above by big bubba at a 6' cutter for the MX, really no point in moving from my 5' Landpride 2660 that I'm using now. That's only 20% more cut per pass and 263% more hp needed (6ft. cutter with MX5800). If I'm sticking with my 5' cutter, maybe I should rethink the whole idea of going from my 19 hp L2501 to a MX5800 with 50hp (pto hp numbers). Thanks to everyone for the reality check, definitely didn't see this coming. The loader lift is double and 3 pt. is significantly more for the MX vs. L2501. So I guess its go a lot bigger M6060 or 7060 or just stick with a MX4800 for the loader/3 pt. increase lift capacities.
I was wanting to stay away from a M series because most of the time it would be loader type work in the woods with the HST. Once or twice a year max I would cut the fields (3 different fields totaling 26 acres).
/ Questions on MX machines #12
Do you use the 2660 with that L2501 successfully?
If so, while a ten-foot may be excessive, your particular use can may work fine with an MX5800 and a much larger cutter.
Some people see 50hp at the PTO and hear "ten foot" and cringe... but then they may be cutting substantially different stuff than you do. If you're happy with 19hp driving a five foot cutter (other than the time it takes)...
I think I use the 2660 cutter successfully with the L2501. It is a fuzz slower when the grass is really thick or when the brush is way overgrown. I'm was trying to take back portions that were neglected for years. I absolutely love the 2660 cutter, its a complete tank. I bought it several years before I got my L2501 from a guy in Iowa, he used it twice (my tractor is in the Missouri Ozarks). I used to own a Kubota M59 TLB in 2009 to 2011, but the cutter never got used on it. I do check my cutter slip clutches every year and take them apart.
The L2501 is a little misleading, the hp was measured at 2200 rpm to get right under the emissions cut off. So I'm going to a bigger tractor mainly for the loader and 3 pt, but still need to know my limitations on a rotary cutter. It looks like an 8' cutter is available from Landpride in the "medium duty" category. A 60% increase in cut width is worth doing, it's just a 20% increase didn't make any sense.
/ Questions on MX machines #14
I run an 8' flail on my L4060. I have to go pretty slow doing a full cut in heavy grass. But here in Colorado we dont have much moisture or the resulting grass. It's usually thick towards the bottom of slopes & what not. Most of the time I'm speed limited by rough terrain as opposed to HP. But the HST means I can trivially adjust my speed to go as fast as HP will permit. With a bad back I'm a fan of going wide & slow. Smoother ride for me & my equipment.
Your mowing conditions might not be at all like mine though. I can easily imagine a L6060 not being enough for any reasonable pace with my flail in wetter climates with lots of thick grass. Thick grass takes a lot more HP than light or moderate brush, suprisingly.
/ Questions on MX machines #15
I run a Landpride RCR1884 (84") with my MX5800. In very tall weedy pasture it barely even seems like it is working the engine. It has plenty of power for anything I mow.
/ Questions on MX machines #16
On horse pasture we have 40 horsepower tractors mowing with that mower. Low horsepower requirements of multi spindles!
/ Questions on MX machines #17
ChemE: perhaps. if you go that route, recommend loaded rear tires. I have a twin 8' hd cutter (3ph) & love it. twin does have it's advantages, far better than single 7' cutters.
personally still skeptical in your case, but could well pan out for you. you have a big purchase(s) ahead of you, best of luck.
/ Questions on MX machines #18
Hi All,
ChemE
FWIW, the MX series is being redesigned and the new models will likely be previewed at the September dealer's meeting. Know nothing about changes, etc.
I agree with Rob and Bubba. A 10' rough cut mower, even a pull behind model, is too big for a MX5800. I use a HD mounted 6' Woods BB720X with my L6060 (same engine as the 5800 but tuned to produce a bit more power) and it's often all it wants. You can probably get by with a twin spindle 8' pull behind model if you are in no great hurry and/or cut often.
SDT
/ Questions on MX machines #19
If you're cutting the fields with a rotary cutter, I assume you're not trying to actually make hay from it, just keep the fields tidy. I'll avoid suggesting you get some self propelled mowers (grazing animals). Would a flail mower meet your needs? I think you can run quite a bit wider flail than a rotary cutter, and if you're mowing a couple times a year then you're unlikely to grow any brush that a flail couldn't cut.
/ Questions on MX machines #20
I bought a Mx5200 & find it has plenty of power
Reason I went 5200 & not 5800 is I assumed same engine stressed less will last longer
This coming from a guy who has always bought largest in a series with all bells & whistles
Don’t miss anything
Andy
